Power FC additional Injectors on pfc
Old Mar 12, 2004 | 06:11 PM
gzon's Avatar
Hi guys. Im about to make some changes to my fuel system and is thinking about adding some injectors. I have heard and read that you can add a pair of 850:s to the secondaries.
But I have another idea. I want to add four 444cc top feed injectors using a "flange" like the one the datalogit guys sells. I have the injectors and they are high impedance 12.5ohm.
If I just connect these in paralell I get 6.25ohm each and the injector setup will be 994cc primarys and 1294cc secondarys.
Will the chip driving the injectors handle this? If not, could it work by placing resistors in serie with the injecotrs?
thanks!
/Martin
Old Mar 12, 2004 | 10:31 PM
cewrx7r1's Avatar
Eye In The Sky
The stock injectors are 13.8ohm. With your 6.25ohm, you will need an inline resitor for each paralle set.
Old Mar 17, 2004 | 03:46 PM
gzon's Avatar
doesnt the voltage get to low if you put a resistor on it?
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
connerfd3s
Sep 19, 2015 05:58 PM
