possible? twin turbo 12a?
Old Mar 12, 2004 | 04:54 PM
i was just wonding if it would be possible to put 93 rx7 twin turbos on a 12a using the jdm 12a turbo manifold? im not worried about any adapaters or anything...everything can be made. i just wanna know if it will work? and if so how much hp to a stock 12a u thin it would make?
(i realize i would have to get a new carb setup and new exhaust)
Old Mar 12, 2004 | 05:11 PM
Tanjo's Avatar
Royale with cheese
That reminds me. Ive been dreaming of finding a couple of 626 turbos in the junkyard, taking the turbos off of them, and having twin sidedraft webers, one for each two ports, and having the turbos just go straight into the carbs. no intercooler though. one carb and turbo per rotor. that would be sweet.
hornbm's Avatar
FD > FB > FC
well yeah it'll work, turbos just dont stop working on a certain engine. as long as you make an adapter it'll be fine. Honestly I dont see what the point it though 13B>12A, besides the stock FD twins are junk anyway.
Old Mar 12, 2004 | 05:18 PM
well inless i get some more replays that say no way...im ording the turbos in like 3 days (i can always upgrade later after everything gets worked out) and ill be the first one to do this??? first to my knowledge at least.
Old Mar 12, 2004 | 05:20 PM
Anex 570's Avatar
It Runs!
How many have you owned? Also what reason were they junk?
Old Mar 12, 2004 | 05:33 PM
cosmicbang's Avatar
Had 2 and "junk" is one way to put it... They can work but you might want to consider a big single turbo instead.
Old Mar 14, 2004 | 07:51 AM
YOU CAN DO IT....... 12a twin turbo... right on!!! ok I am looking up Hp info for you 10lbs from the dyno shops in CA, cause we might be doing the same thing and will pass all we know to ya...right on!!
Old Mar 14, 2004 | 08:58 AM
FB II's Avatar
this sounds like a good idea to try. hmmm, i have access to a set of twins from an fd. MUHUHAHAHHAHAAAAAAAAAAAAA!!!!!!!!!
Old Mar 14, 2004 | 10:49 AM
DAMNIT DONT TAKE MY IDEA...i wannt be first...j/k tell me wut ur HP is man.. also wut setup are yall gona be runin ??? (carb setup? exhaust? which manifold? any port job? intercooler?). my brother just got his WRX and put his hks bov on...I WANT THAT SOUND...plus something to try and keep up with him till i get my '06 rx8 turbo. at the end of this week i SHOULD be able to get a 12a manifold..carb hat..and maybe the twins. so this process shouldnt take TOO long. kepp me posted tho!
Old Mar 14, 2004 | 11:59 AM
Directfreak's Avatar
I am a Jeeper Now.
Nothing is impossible, so it can be done - technically.
The stock FD turbos are usually cooked and fried.
They are tiny, and you'll never get them to work
sequentually.
My advice - don't waste your time.
I've seen REAL twin turbo setups (with two 60-1 turbos)
on bridge-ported 13B's. The experiment failed, and it had horrible throttle response and so-so power.
The owner switched to a larger single, and is putting out over 650 to the wheels.
Don't re-invent the wheel. It gets expensive. Go with
what has been proven to work.
Go single, and go fast.
Old Mar 14, 2004 | 03:02 PM
rotary emotions's Avatar
HEAVY METAL THUNDER
There's usually no point in going twin turbo, unless on those engines where space dictates against single turbos (V-engines usually use one per bank). The only exception is where you can get them to run in sequential mode: this works as if you'd have a small (fast spinning, no lag) turbo at lower rpm, and a big (more lag, but more power) at higher rpm. The idea is to have best of both worlds. When replacing the stock twins on an fd, you will loose some low end response. But in your case, there's no way you're going to use them sequential, so there's no point in using the fd twins.
This said: it is possible, since a turbo is a turbo.
Old Mar 14, 2004 | 04:47 PM
REVHED's Avatar
Hunting Skylines
There's a few shops here offering twin turbo kits using Series 4/5 turbos. They make some decent power by the looks of it.
Old Mar 14, 2004 | 05:47 PM
FC Wanna-B's Avatar
i say screw the whole TT setup idea and go 20B swap!!! lol
Old Mar 14, 2004 | 06:27 PM
SUPERCHARGER!
Old Mar 14, 2004 | 07:12 PM
Fuel524's Avatar
if it was a good idea then more 7's would be TT just think about it all your high HP 7's are single turbo all your supras convert to single plus it is alot less $$ unless your loaded and want to just do it to do it then keep on keepin on, and may the force b e with you.
Old Mar 14, 2004 | 07:38 PM
timmya2's Avatar
nos
Old Mar 14, 2004 | 08:08 PM
QuagmireMan's Avatar
Registered Offender
how many miles would the engine run under boost of twins 10, 15 miles ?
get a renesis
Old Mar 14, 2004 | 08:09 PM
Dysfnctnl85's Avatar
Acquiring money pits
I was under the impression that a sequential setup with one large and one small turbocharger would never work...
Old Mar 15, 2004 | 06:44 PM
REVHED's Avatar
Hunting Skylines
That's not exactly true. Most of the quickest drag cars are starting to run twin or even tripple turbo setups. Talking about 20B's of course.
Old Mar 15, 2004 | 11:47 PM
abeomid's Avatar
Well as directfreak said don't waste your time.
Most of the FD turbos need rebuild already b/c of the heat.
Plus to have a true squential twin setup you need all the junk (vaccum hoses and solenoids) from the FD which trust me is a pain in the *** to figure out. If you are not running sequential then u will have two small turbo with large lag which will be useless.
If you want to be different with the twin setup and have the money and time to spend on it, perhaps you can get couple of small turbos like GT25's and work on that. But you are better off with a single turbo, easier and cheaper and been done before.
Good luck,
O
streetlegal?
Mar 17, 2022 02:46 PM
Turblown
Vendor Classifieds
Aug 18, 2015 10:01 PM
