I THINK i found the problem! (pics) hose thread part 2
Old Mar 12, 2004 | 02:29 AM
timmya2's Avatar
Arrow I THINK i found the problem! (pics) hose thread part 2
hey check out these new pics..
(overview: i am experiencing alot of heavy fuel smell thay is driving me crazy because its getting in my clothes and is slowly killing me - the problem is.. one or more hoses are just venting in the atmosphere and the fumes arent being consumed by the engine as it should)
note: only one hose is connected to my charcoal canister and i dunno where the other hose is . a pic of it can be found here
------- on with the show------
i found a hose thats not connected to anything but i dunno wat hose it is.. can anyone tell me?
here is a pic of that hose
another angle
here is another pic of the hose.. and also i am pointing to a rubber valve of sum sort that is blocking off one of the metal hoses..
another pic of that mystery rubber valve
me holding it for a closer look - and im wondering maybe i can just use this to clock off all the open hoses can anyone tell me if this is safe or not?
and also i found another hose thats pointing down that is not connected to anything.. its coming from the firewall and points down like a un horny *****..
can anyone help me
please please please
oh and wat is this hose i am holding to ->
pic here ?
cheers guys
Old Mar 12, 2004 | 02:41 AM
jorx81@aol.com's Avatar
Still Dreams of 3rd Gen
oil neck, or case breather below it.
not sure which but it definetly goes to the fuel tank right?
why so you still have that emissions stuff?
Old Mar 12, 2004 | 02:53 AM
And turn the gas inlet on that carb 90 degrees counter clockwise.
Old Mar 12, 2004 | 03:38 AM
timmya2's Avatar
Old Mar 12, 2004 | 06:19 AM
Rx7carl's Avatar
Airflow is my life
Trace that first hose dude. I bet it goes to your trasnsmission. I'm %99.5 sure its for the transmission. Its your kickdown line. It heeds to be hooked to manifold vacuum. Looks like whoever added the weber setup just disconnected it (dumbass). Not you, whoever put on the weber setup.
Old Mar 12, 2004 | 06:49 AM
timmya2's Avatar
carl.. wat is a kickdown line..
and where do i put it in the manifold???
i dont think there is any other holes to put it on
cheers
Old Mar 12, 2004 | 06:58 AM
Rx7carl's Avatar
Airflow is my life
It helps the transmission shift correctly under load. Find a source of manifold vacuum (tee off the brake booster nipple if you have to) and hook into it.
Old Mar 12, 2004 | 07:28 AM
timmya2's Avatar
where is the brake booster nipple located
sorry
Old Mar 12, 2004 | 07:50 AM
you know where your brake mastercylinder is? (Where you add brake fluid) That big circle black thing behind, should have a hose running from it, to the intake manifold..... T into that... (little plastic T tube) and hook up that tranny line......
If the brake booster line doesnt hook to the manifold.... I say dont take your car back to that place... or let whoever put it on, touch the car....
Laters Andrew....
Old Mar 12, 2004 | 07:53 AM
and for ***** sake, put a real fuel system on
(better pump, new filter, fuel pressure regulator)
Laters, Andrew
Old Mar 12, 2004 | 08:08 AM
timmya2's Avatar
ok ill trace that hose in the morning and check...
and wat dya mean if the "If the brake booster line doesnt hook to the manifold" ?
and when u said "That big circle black thing behind"
is it this pic here?
cheers
Old Mar 12, 2004 | 08:17 AM
Rx7carl's Avatar
Airflow is my life
The booster hose needs to be hooked into the manifold to get your power brakes to work.
Old Mar 12, 2004 | 08:26 AM
timmya2's Avatar
alrite so that means its connected right.. else my breaks wont work..
ok so tomororw i need to by a tee peice from the auto parts store.. and somehow make that hose reach to where the break booster hose is and tee from that?
cheers
Old Mar 12, 2004 | 08:29 AM
Rx7carl's Avatar
Airflow is my life
Your brakes would work, youd just have no power assist. Meaning youd have to press reall hard on the pedal to get it to stop.
NO, tee off the booster hose as close to the intake manifold as possible. Then run the transmission line to the tee.
Old Mar 12, 2004 | 08:35 AM
timmya2's Avatar
if yur not too busy... can ya give me a rundown on how that thing works and why the hose needs to be connected there..
is that like sucking air in.. or blowing air out?
or sumthing else?
and after i connect this transmission line to the manifold.. that still wont stop the smell huh?
cheers
Old Mar 12, 2004 | 09:17 AM
Rx7carl's Avatar
Airflow is my life
Suuuuuuuure!
Learn about power brakes.
http://auto.howstuffworks.com/power-brake.htm
As for the transmission hose, it goes to a vacuum valve on the transmission. This gives better control of up and downshifting.
As for the crankcase vent, it pulls the fumes out of the crankcase into the engine. This keeps oil contamination to a minimum.
No it wont stop the smell. You need to set up your fuel venting system. Theres a small line (vent line) from your fuel tank that comes out in the engine compartment along with your main fuel and you fuel return lines. This small vent line goes to the charcol cannister. HTH
Old Mar 12, 2004 | 09:35 AM
timmya2's Avatar
thanx dude
ill msg this thread again if i come across a problem.. and take pics of it and illustrate it if i have to..
i wont give up until i understand
Old Mar 12, 2004 | 09:31 PM
timmya2's Avatar
--update--
i found another hose thats not connected anywhere.. what is this and where does this connect to?
also.. is this supposed to be open like this? what is this thing?
and last but not least.. the tranny line wont reach the manifold.. i was gonna tee from the brake booster hose but as u can see the brake booster hose is twice as thick and wont reach it.. any suggestions?
oh and wat is this hose i am holding right here?
cheers
Old Mar 12, 2004 | 09:52 PM
timmya2's Avatar
OOPS
when i said "is this supposed ot be open like this.. i meant to put this pic here
Old Mar 12, 2004 | 11:05 PM
GavinJuice's Avatar
Leave A Message
Jesus that car is jerry rigged up the gazoo. Stuff hanging and capped off everywhere.
Old Mar 12, 2004 | 11:32 PM
timmya2's Avatar
Old Mar 13, 2004 | 10:14 AM
Rx7carl's Avatar
Airflow is my life
Either replace the trans hose with a longer one or extend it with another piece of hose.
Old Mar 13, 2004 | 10:16 AM
Rx7carl's Avatar
Airflow is my life
Hey man, shoot a pic of each side of your engine compt from enough distance to show all the hoses and crap on that side, mainly the left side. You need to remove a bunch of **** and get the rest hooked up right.
Old Mar 13, 2004 | 10:49 AM
On my 84 GS the hose to the white sensor your holding in your 3rd pic is to the air conditioning throttle assist valve. If you don't have AC, plug it. I did. Also, get a Factory Manual. all sensors are color coded.
alphawolff
Nov 17, 2015 05:57 PM
gtcd
30
Aug 19, 2015 02:44 AM
