ACV plate problems, i broke some bolts and im SCREWED HELP ME! (haha)
Old Mar 9, 2004 | 11:12 AM
Ok the bad word choice probably brought you in here to insult me, but while removing my rats nest, the two lower bolts that held on the ACV snapped off, and are jammed in the block. I silicon'ed the plate on for now, but it leaks like a sive and makes my car idle at like 1k. I need to get these friki'n bolts out! Should i just get a new intake and carb?
Old Mar 9, 2004 | 11:28 AM
Tom's Avatar
Tom
Whack 'em and stack 'em
From: Clarksburg/Bridgeport WV- North Central Appalachia
I usually use an easy-out (I think its called a bolt extraction something or another). I bought my set at Sears. Problem is, you'd really have to take the manifold off to do this properly. You have to drill a small hole in the broken bolt to insert the easy out (to grab the bolt)..
Plus- that is a really small bolt..You may have problems drilling a starting hole..
In any event-They're easy to use. I broke a lot of bolts on an old tractor I restored..The easy-out is a life-saver..
An easier solution may be to use JB weld the plate on and hope that last screw is enough to keep the integrity of the bead. You'd still have to take the manifold off though..
Someone else may have a better trick(s), but I know the easy out works..
Old Mar 9, 2004 | 07:53 PM
hornbm's Avatar
FD > FB > FC
Just drill and tap it, use a heli coil if you want too.
Old Mar 9, 2004 | 08:12 PM
GavinJuice's Avatar
Leave A Message
Yea buy yourself a bolt extraction kit, it should be a wise investment and prove it's worth down the line. Drilling will work but it's a pain in the *** especially if it's in a complicated place.
Old Mar 10, 2004 | 10:19 AM
brianw's Avatar
I think I would remove the intake and try the easy out. If that don't work out you could always redrill and tap them at that point going to a bigger size. Since you don't intend on using the acv you could go to a larger size if needed. I'm afraid that this would be next to impossible wtih the manifold installed thought.
Old Mar 10, 2004 | 12:17 PM
slashdawg00110's Avatar
RTFFAQ
All good ideas.
But if you're not going to put the ACV back on, why not just JB Weld the plate to the manifold?
astrum
24
Nov 15, 2017 08:44 AM
Frisky Arab
13
Aug 18, 2015 05:30 PM
Brice_Brice
Aug 18, 2015 10:42 AM
druggist
Aug 15, 2015 07:05 AM
rkhanso
Aug 13, 2015 11:40 AM
