motorswap
Old Mar 9, 2004 | 09:41 AM
mazdapower234's Avatar
motorswap
i was wondering i have an 88 with the 13b rotary. what i would like to do is put the 20bt motor in it. will the 20bt rotary drop straight in or will i have to move the engine bay around to make it fit.any help would be apreciated.
Old Mar 9, 2004 | 09:43 AM
DelSlow's Avatar
Hot Dicken's Cider
Yes, its a direct bolt in. No modifications are needed whatsoever. However, this has never been done before, so there would be no reason for there to be a section dedicated to 20b swaps.
Old Mar 9, 2004 | 09:46 AM
RRTEC's Avatar
Rotartist
Hope you have 10k to spend...... It is very unlikely you will ever do this swap.... Just do a t2 swap and be done with it, you can have a hell afast t2 for 1/4 the price of a 20b completed setup and there will still be parts availible if something breaks...my .02 to answer your question No from what i have read it takes some massaging to get it to work right it's not a drop and go setup....... good luck
Old Mar 9, 2004 | 10:25 AM
also would i need to have a new wiring harness or would the wiring harness plug in to the motor.
Old Mar 9, 2004 | 10:28 AM
rxcollector's Avatar
isnt the 20b a 3 rotor motor??
Rxmfn7's Avatar
Do a barrel roll!
Youll need to go with a standalone EMS. There is a 20B section on this forum..
https://www.rx7club.com/20b-forum-95/
Old Mar 9, 2004 | 10:43 AM
yeah the 20b is a three rotor motor. i know the my ems itself will have to be replaced but i was not sure as far as the engine bay harness or not.
Old Mar 9, 2004 | 06:44 PM
johnisenglish's Avatar
Yes.
This is about as far from a bolt in swap as you can get. Chances are you're going to be using an engine mangement system that has its own harness anyway.
Old Mar 9, 2004 | 06:53 PM
Yes, you will.
Old Mar 9, 2004 | 07:03 PM
Yes, you will.
Old Mar 9, 2004 | 08:01 PM
RETed's Avatar
http://fc3spro.com/TECH/SWAP/COSMO/20b.html
The increased power is going to break all your NA drivetrain parts.
-Ted
Old Mar 19, 2004 | 01:38 AM
yea you would need to basically need to do a T2 swap except instead of the 13BT u would be putting in the 20B. I am debating doin this swap myself, I have been told it gets about the same gas mileage but im still curious about emissions... But with a standalone ems i guess you can adjust it accordingly
Herz
Drifting
Dec 20, 2011 09:10 PM
TurboB18C1Teg
Dec 24, 2003 02:09 PM
