still nothing
Old Mar 8, 2004 | 10:21 PM
capri93's Avatar
The thing
still nothing
well i looked at it some more and found that the dick that had it befor me took all the fuses out of main fuse box well i replaced them all and still nothing no interier lights no dash lights no starter nothing the head lights go on but thats it last thing to check are the fuseable links in the stering column but thats it
few more problems there some rubber lines 3/4" or so that are pinched and taped off they come of the pass. side of the engine from what i can see but any way the big thing is figuring out the electical problem
Old Mar 8, 2004 | 10:28 PM
Did you check and make sure the chasis grounds are connected. I know I forgot to put a ground back on once and my car acted like the battery was dead.
Old Mar 8, 2004 | 10:31 PM
capri93's Avatar
The thing
where does it conect to ? directly to the batt or what ? but wouldn't the head lights not work?
Old Mar 8, 2004 | 10:38 PM
QuagmireMan's Avatar
Registered Offender
does anything electrical work on the car?
Old Mar 8, 2004 | 10:39 PM
capri93's Avatar
The thing
the head lights high and low beam and the high beam symbol on the dash and that is it
Old Mar 8, 2004 | 10:42 PM
Registered Offender
try to get a new battery in there, and upgrade the grounds by making sure the frame is grounded to the negitive terminal on the battery.
Old Mar 8, 2004 | 10:48 PM
capri93's Avatar
The thing
it is a brand new just picked up 750cca battery the ground might be the problem but again wouldn't that effect the head lights as well
Old Mar 8, 2004 | 11:23 PM
capri93's Avatar
The thing
from looking at the faq page i think i'll try the fusible links and the ground cable
nother thing a few of you guys were talking about getting rid of the shaft driven fan and replacing it with an electric where do i get the power from for this to have it work off the thermostat or should i just have it run when ever the car is running
Old Mar 9, 2004 | 09:51 AM
capri93's Avatar
The thing
any body
Old Mar 9, 2004 | 10:03 AM
Metallic_rock's Avatar
Ride 'n Style
this should help- wiring diagrams!!!
http://www.wankel.net/~krwright/cars/rx7/wiring.html
