Sponsored by: CARiD
1st time it wont start...
Old Mar 8, 2004 | 07:59 PM
MADBOOST's Avatar
i live in MN and there is plenty of snow and this year i havent found shelter for my FD but weird thing is, i never had a start problem and the 1 night it does sleep in the garage the F ing thing wont start.. but it started once when i had to move it back a foot to open the fridge door 1st try like always, then the next day the thing juss wont start. is this a common problem with these things? what should i do? i thought maybe i flooded it somehow, prolly not but i didnt know where else to start but checkign the spark plugs. if i did flood it it wont do a rolling clutch start right? kuzz of fuel injection? or is it somehow different for rotories? how the f do i get to the spark plugs? do i go from under the car? i cant even see them, its like rocket sugery......
i would appreciate any input from any1... i dont know wtf im doing... thanx
dam thats a lotta text
Old Mar 10, 2004 | 09:27 PM
Rotor_rampage's Avatar
look on drivers side of block, down by the oil dipstick area.its kinda easy once you take them in and out a few times.there is a difference though.there are two with blue lines on the end of the plug ,and then theres two all white plugs,the two blue go in the top two holes, the two white go in the bottom two holes ..dont forget though cause it will run like sh------t.take plugs out turn engine over with the gas peddle to the floor and crank until you dont smell a heavy gas anymore ,get new plugs cuz those ones are probably crapppp... put the plugs in the right holes and make sure all the wires go back on right too then try it............
lt1_rx7
Blue Ridge Rotary Run
46
Oct 9, 2015 03:11 PM
craaaazzy
Comments and Suggestions Archive
Aug 21, 2015 02:00 PM
Marty RE
Aug 13, 2015 11:19 AM
