Vid - Bridgeport Startups
Old Mar 7, 2004 | 09:53 AM
Wargasm's Avatar
Weird Cat Man
Here's a super quick clip of my friend Glean's RX-7 starting up with his new Pineapple bridgeport. (all 4 intakes are bridge).
File size is about 6 megs (divx) and is 44 seconds long
ftp.zeroglabs.com
username rx7
password rx7
path and file:
/Car_Movies_2/movies18/Glean_Bridgeport_Startup.avi
Old Mar 7, 2004 | 10:18 AM
Maxthe7man's Avatar
Freedoms worth a buck o'5
password no worky...
Old Mar 7, 2004 | 10:25 AM
apneablue's Avatar
worked for me...Type slower and make sure you have CAPS off.
Old Mar 7, 2004 | 10:27 AM
Maxthe7man's Avatar
yeah I did, just get password protection error..
Old Mar 7, 2004 | 12:09 PM
Wargasm's Avatar
Weird Cat Man
sometimes you get that error if you're using a lame program like IE or Netscape to do FTP and the FTP has too many users. A real ftp program would auto-reconnect for you and would also tell you "too many users" not just "duh... error"
Anyhow, just keep trying.
Brian
Old Mar 7, 2004 | 12:10 PM
Wargasm's Avatar
Weird Cat Man
I increased my number of users from 6 to 10, hopefully that will let more people in
Brian
Old Mar 7, 2004 | 12:27 PM
eViLRotor's Avatar
Brother of the Rotary
Also, good to see that if I ever wanted to see the Paris Hilton Video again, I'll have a place to go...
Old Mar 7, 2004 | 03:31 PM
Maxthe7man's Avatar
Sounds good, what turbo and what seals in that motor?..Max
Old Mar 8, 2004 | 02:13 PM
peejay's Avatar
Old [Sch|F]ool
JEEZ that thing idles smoothly!
Old Mar 8, 2004 | 02:35 PM
Wargasm's Avatar
Weird Cat Man
max: Seals are two piece mazda seals as far as I remember...
that's a "secret spec" turbo from a local shop. I took it apart and measured and inspected everything and from what I can tell.... "secret spec" means 60-1 wheel, 0.70 housing, P trim exhaust, and .84 housing. Some secret huh? Oh well. I'm interested to see how the .84 turbine housing works on the bridge. The dyno will tell the tale!
Brian
Old Mar 8, 2004 | 06:50 PM
Maxthe7man's Avatar
yeah... I am thinking that turbo is a little light for that application, but it should spool like mad, I loved where the compressor started to kick to every combustion event, really neat....Keep us up to date, and yeah sounds wicked....Max
Old Mar 8, 2004 | 07:08 PM
razorback's Avatar
You've Been Punk'd
you ever get that tv51 working
Old Mar 8, 2004 | 07:54 PM
Wargasm's Avatar
Weird Cat Man
Well here is the thought on the turbo... My feeling is the exhaust housing will be too small and you need a 1.15 or 1.32. Rob/Pineapple told my friend on the phone that the .84 is OK because it will spool sooner and help fill in the torque in the midrange where the bridgeport might not do so well.
We'll see.....
Old Mar 9, 2004 | 06:54 AM
Maxthe7man's Avatar
I am running a p-trim 1.15 on a streetport right now, with stock ports it had some lag, but with the large streetport, it spools alot like a stock TII turbo, basically whenever I touch the gas I build boost now, I am thinking reversion with .84 is gonna be a problem, and the 60-1 may not deliver enough airflow on the top end for the full bridge... But give 'er a try and see what happens.....
Razorback... still waiting for the TV51 to come in the mail....poor mailman, that thing must wiegh 40 lb,s.......Max
Old Mar 10, 2004 | 12:27 AM
88fc3sw/HX83's Avatar
WOW, sounds good. I noticed that you have quite a collection of videos
Old Mar 10, 2004 | 09:33 PM
Swolbynos's Avatar
Newb
i guess i am not comp savvy enough
could someone post a direct link or go into detail on what to do with this?
thanks
Old Mar 11, 2004 | 08:40 PM
j200pruf's Avatar
RIP Icemark
copy the URL ftp.zeroglabs.com and paste it into Internet Explorer (or whatever browser you use), then there will be a prompt asking you to enter a username and password, just type in rx7 in both tect boxes.
Old Mar 13, 2004 | 04:25 PM
DonaldC's Avatar
Definitely go at least the 1.15 ar. on the exhaust side. The .84 will probably choke the car on the top.
Old Mar 14, 2004 | 12:19 AM
DELTA_Rotary's Avatar
Bourbon King
Hey Wargasm how much to stick all those Vids on a CDs and mail them to me?
James Knox
Oct 22, 2015 05:08 PM
LongDuck
Oct 7, 2015 08:12 PM
Neo
Canadian Forum
Sep 14, 2015 09:09 AM
