i know you guys know the answer to this
Old Mar 6, 2004 | 05:49 AM
timmya2's Avatar
ok well i just put in a brand new spakin weber 48ida..
the car idles better.. smoother.. and is so much better to drive in total
one problem
when i press on the throttle.. there is a spot where its hard!
like i have to press on it hard to get pass this spot.. but then the car will get alot of gas.. and make the rev jump suddenly because its not a smooth press..
like the old weber didnt have this problem.. i would press the gas and from top to floor.. its all the same pressure u put on the pedal
the new one has this spot thats hard to press but when u pass that particula spot it its normal again..
Old Mar 6, 2004 | 05:50 AM
timmya2's Avatar
heres a picture so u guys understand wat im talkin about
Old Mar 6, 2004 | 06:05 AM
frode's Avatar
vroom vroom!
have you tried to lube the throttle wire?? maybe it is getting a bit sticky..
Old Mar 6, 2004 | 07:05 AM
timmya2's Avatar
ah..maybe the throttle wire is a bit tight huh?
hmm..
actually i was nudging on the actual weber throttle lever.. and i could kinda feel the hard spot too.. or maybe its just my imagination
btw the weber is brand new.. as in bought straight from the shelf and bolted it in...
Old Mar 6, 2004 | 07:07 AM
timmya2's Avatar
any other suggestions guys?
thanx heaps
Old Mar 6, 2004 | 07:10 AM
1rx7owner's Avatar
Lifes a garden dig it.
mine did the same thing and I just oiled the little bearings on the carb itself. just a couple drops of 3-1 oil on both sides and is smooth as ever.
Old Mar 6, 2004 | 07:13 AM
timmya2's Avatar
which part of the carb?
was yurs a brand new carb?
cheers
Old Mar 6, 2004 | 07:35 AM
1rx7owner's Avatar
yes I got mine brand new. the bearings that the throttle shaft go through.
Old Mar 6, 2004 | 07:41 AM
timmya2's Avatar
got a pic of it by any chance?
and wat kind of oil did ya use
cheers mate
Old Mar 6, 2004 | 07:50 AM
timmya2's Avatar
or if you can.. label where i have to put oil in on this pic
cheers
Old Mar 6, 2004 | 08:02 AM
sa22c_Drifter's Avatar
Hey where did you buy your carb and how much did it cost. I've been wanting to buy a new carb for my 12a but I don't know where to start or go??.
Old Mar 6, 2004 | 08:18 AM
timmya2's Avatar
racingbeat.com
Old Mar 6, 2004 | 09:05 AM
Siraniko's Avatar
RX for fun
how big are the venturies. try using a smaller one. Say if youre using a 44, try 42 and work your way up. also, idle jet makes a big difference too. it works from idle til about 3500 rpm, then the main will kick in. 65 is the base line but I prefer 75 or 80.
Old Mar 6, 2004 | 10:15 AM
1rx7owner's Avatar
oil under where the arrows are pointing, take those little covers off and oil the bearings underneath. I just used some 3-1 oil. I am sure any light oil will work.
Old Mar 6, 2004 | 06:16 PM
timmya2's Avatar
will engine oil work?
Old Mar 6, 2004 | 06:26 PM
timmya2's Avatar
my venturis are 37mm
Old Mar 6, 2004 | 06:29 PM
mmasid's Avatar
Sure. Anything would work. Bicycle chain lube or WD-40, anything. It will attract plenty of dirt too.
Old Mar 6, 2004 | 07:06 PM
timmya2's Avatar
so yur saying thats a bad thing?
Old Mar 6, 2004 | 08:33 PM
Lotus00's Avatar
no, just use some WD-40. dont over do it and you wont attract too much dirt. even if it does get dirty, you can just wipe it off.
Old Mar 6, 2004 | 10:33 PM
timmya2's Avatar
is there a way of getting to those bearing wihtout having to pull out the whole carb out of the car..
Old Mar 7, 2004 | 12:06 AM
seanrot's Avatar
Always waiting for parts!
I would say check for a kink in the throttle cable. Whats the set up on your carb? jets and stuff like that.
Old Mar 7, 2004 | 01:03 AM
timmya2's Avatar
fixed it..
sprayed a generous amount of wd40 into here
Old Mar 7, 2004 | 02:03 AM
seanrot's Avatar
any word on the jet settings?
Old Mar 7, 2004 | 06:57 AM
Bayce's Avatar
Man - I currently have the SAME problem. . . But I still have my standard carb on my 12a. I pulled the Air filter off the carb and noticed where the Throttle cable goes into the carb, a bunch of levers and ****, I too just sprayed WD40, and it SEEMS to have made it a little better. . .I still notice a lttle "area" that i have to pass as I depress the throttle - hope all the connections are ok and the cable too. . .
Old Mar 7, 2004 | 07:09 AM
timmya2's Avatar
this is wat i followed
taken straight from ausrotary member
"I would suggest the following.
38mm chokes. You might have to get a set machined if you cannot find any.
F2 emulsion tubes
190-200 air jets
180-190 fuel jets
F10-65 idle jets
Alternatively you can use
F11 emulsion tubes
120 air jets
180-190 fuel jets
F11's do seem to be more suited to big ported engines though, and in my experience they do not work as well in normal engines as the F2 emulsion tubes. "
i done the second setting
(F11 emulsion tubes
120 air jets
180-190 fuel jets )
.. but i have 37mm chokes instead of 38mm
