Alternator Reassembly
Old Oct 24, 2001 | 11:46 PM
Has anyone taken apart their alternators? I'm having a hell of a time trying to push the brushes down while getting the the rotor's shaft back into the housing. Is there a trick way to do this? I figureI can polish the outside while it's all apart, but I'd be nice to have an alternator again..
Old Oct 27, 2001 | 12:34 PM
bump
Old Nov 2, 2001 | 12:19 PM
Still having a hard time putting this alternator back together. Is it a matter of removing the rear bearing and using it to push in the brushes. Then putting the shaft and rotor back in the case, or do I need to remove everything including the rotor from the shaft and reassemble as in the diagram? Any advice would be much apreciated..
Old Nov 2, 2001 | 12:24 PM
JaySpec7's Avatar
I'm having the same problem.. but i can't get mine totally apart.. i can't get the shaft off the front housing... I think i should take it to a machine shop...
Old Nov 2, 2001 | 05:22 PM
David Bryant's Avatar
Newbie
Alternator
If it is simliar to my "85" there is a small hole in the back of the alternator just under the center were the bearing goes into. Slide a paper clip into the hole (from the back) to hold the brushes up out of the way when assembling the bearing in their place then remove the paper clip.
Captain Hook
13
Oct 4, 2015 06:35 PM
Robrods64
Oct 2, 2015 07:56 PM
WANKfactor
Sep 29, 2015 01:14 PM
