Greddy FMIC install help????
Old Oct 24, 2001 | 07:05 PM
1.3literv8eater's Avatar
I just purchased the new kit from greddy for my T2.....I need to know what to do with the 2 lines that went into the stock ic. (the one line frm the upper intake to the ic and the line from the accelerated warm up sol. valve to the ic) as of now i have them capped off and the accelerated warmup valve isn't on. The car will not stay running at idle.....please help.....i wanna get this damn thing done...thanks
Old Oct 24, 2001 | 07:14 PM
13BAce's Avatar
On a long vacation
Those are just for the fast idle and BAC valve. Not having them shouldn't affect the idle if everything is capped off. If you have a leak in your IC piping that would cause the stalling at idle. Maybe you popped something loose and didn't notice it?
Old Oct 24, 2001 | 07:17 PM
my bac valve is still on???? i'll check the piping again though
Old Oct 24, 2001 | 08:00 PM
piping is fine....i also removed my emissions controls stuff (acv) at the same time of the fmic install.. i just capped off the 3 lines that went to it.. is all that right? do i have to turn up the idle now
Old Oct 24, 2001 | 08:14 PM
13BAce's Avatar
On a long vacation
You can try turning up the idle with the screw in the TB. If that doesn't help then you probably have a leak somewhere.
Old Oct 24, 2001 | 10:10 PM
i found the two hoses that g into my tid were not in (oops)but i put them in and it still won't idle...im going to look around tomorrow see wha i can find let me know of any more ideas... would taking the emissions stuff off have anything to do with it
Old Oct 24, 2001 | 11:30 PM
13BAce's Avatar
On a long vacation
As long as you block everything off properly it will be fine. Let me know what you find tomorrow.
Old Oct 25, 2001 | 04:28 PM
i turned up the idle a little bit and drove it around the block a little bit and whan i came back it would idle.... i heard a loud hissing sound and i foud it to be two things.. the bottom of the bac vale to the stock intercooler piping had to be capped and the old spot on the lower intake where the line went to the main cat... i plugged them and now it idles even better...... for now thanks for your help.....laterz
Old Oct 25, 2001 | 05:25 PM
13BAce's Avatar
On a long vacation
Good to hear. Good luck.
Old Oct 25, 2001 | 05:47 PM
Flamin' NOS's Avatar
PICS!!!! Must see pics of greddy intercooler!!!
Old Oct 25, 2001 | 06:13 PM
13BAce's Avatar
On a long vacation
Check out http://brfoundation.com/RX-7/ .
Old Oct 25, 2001 | 09:25 PM
i'll get some pics....this is one mean looking intercooler... it took me four months to get it. the core is 25 x13x 3....piping out of ic is 3 3/4.....thanks for the help
cristoDathird
28
May 30, 2019 08:47 PM
immanuel__7
89
Sep 5, 2015 10:23 AM
Clacor
Aug 14, 2015 09:17 AM
gabescanlon
Interior / Exterior / Audio
Aug 11, 2015 05:59 PM
