Running Wheels W/O Hub-centric Rings
Old Mar 2, 2004 | 07:11 PM
Rookie84's Avatar
Well, I got a set of Racing Hart C2s. I bought them used and they didn't come with any hub-centric rings. Is it safe to run them without hub-centric rings or should I stop being a lazy bitch and order those rings? The seller mentioned that he had hub-centric rings but they didn't fit FCs(probably wasn't FC specific) so he just ran the wheels w/o them and didn't have problems. Would it be bad to not have hub-centric rings if I were to push my car hard a lot? Thanks a lot in advance
Old Mar 2, 2004 | 07:38 PM
rotorhead333's Avatar
It's best to have them, but not mandatory. If you put your wheels on the car without them and start to experience a vibration even though the wheels are balanced, I'd say then you probably will need them.
But they are only a few bucks, so yes... stop being a lazy bitch and buy some!
Old Mar 3, 2004 | 12:12 AM
Rookie84's Avatar
lol ok I guess I'll order them and run the wheels w/o hub-centric rings until they come in
Thanks
Old Mar 3, 2004 | 12:49 PM
good job guys
Old Mar 3, 2004 | 03:52 PM
Keep to the right.
Since the wheels have conical lugnut seats, and therefore each seat must be concentric with it's respective stud, it follows that the wheel itself will be concentric with the hub. So I don't think you need them.
Old Mar 3, 2004 | 09:12 PM
travisorus rex's Avatar
Avoid the Noid
You need them. I took mine off when i replaced the bushings and somehow the rings did not make it back on. I have conical lug nuts and that doesnt hold the wheel concentric. When you dont have the rings, the weight of the car is supported on the studs instead of the hub. they might not vibrate when going straight but try doing a full lock turn. Trust me they will vibrate.
Old Mar 3, 2004 | 10:31 PM
sunshine's Avatar
https://www.rx7club.com/showthread.p...hreadid=274204
Old Mar 4, 2004 | 12:31 AM
Rookie84's Avatar
I just bid on the hub centric rings that dicount tire direct has for sale on ebay. Thanks a lot for the info, sunshine!!
Thanks, antiSUV and travisorus rex.
Old Mar 4, 2004 | 12:37 AM
ZoomZoomH's Avatar
i assuming stock rims don't have to worry about this???
Old Mar 4, 2004 | 01:17 AM
artowar's Avatar
FD3SW211E55
Correct.
Old Mar 4, 2004 | 06:54 AM
DamonB's Avatar
Not necessarily true at all. The lugs do have conical seats but for the wheel to be perfectly centered on the spindle you're asking all 5 wheels studs to be placed in a perfect concentric circle around the spindle. You're also asking that all 5 never bend and that you torque all 5 down simultaneously, otherwise once you torque the first stud the wheel is already "set" to the spindle and the other 4 merely clamp it there. That by no means ensures the wheel is centered on the hub.
It's much simpler to just make the wheel hubcentric so that the hub centers the wheel; you're only dealing with one hole instead of five at that point. The other advantage to this is that the studs don't have to support the weight of the car.
FD7KiD
15
Feb 26, 2021 10:12 PM
FD7KiD
Aug 17, 2015 11:50 PM
