how to set the idle
Old Feb 28, 2004 | 07:19 PM
MicahMan's Avatar
That's Nice!!!!
how to set the idle
my carburator is a 4 bbl and i need to set my idle. how do i do this? i only can find one set screw and i think it is the mixture screw. im confused please help. thanks
Old Feb 28, 2004 | 07:38 PM
whitepra's Avatar
What year is your car? In early models there are two mixture sccrews and an idle adjustment. In 81 and up only one. On my 83 the idle srew is a inch or two to the right and below the mixture screw. I don't have a pic to post on it maybe someone else does.
Old Feb 28, 2004 | 08:31 PM
MicahMan's Avatar
That's Nice!!!!
mine is an 83 gsl. i can see one in the center and i couldnt find any others. do you know the settings for it?
Old Feb 28, 2004 | 08:58 PM
kettlman's Avatar
THE ONE. THE ONLY!
all right. the one in the middle is your air/fuel mixture screw. if your car is runnin good, don't mess with it. the idle is on the right, right under the linkage. stock carbs no fun to get to let alone see. but look at where your throttle cable goes to the linkage, the screw will be on the left side of the cable. another thing you can do is to change the position of the cable its self. there is a bracket that the cable fastens to by two bolts. you can adjust those bolts and have your cable tighter. if you don't know that you need to raise the idle, i would do that first. just adjust it to where it stays at an idle and see where the rpm's are. you can always reposition the cable fairly easy if it needsw to be. but for the most part i would look hard for that idle screw( if you have one, it may have fallen out) and do that way.
what is wrong anyways? does it not keep idle, does it idle low,
Microtech
30
Apr 23, 2016 06:37 PM
imitek
Aug 28, 2015 05:28 PM
ncds_fc
Aug 15, 2015 10:06 AM
