Still doesnt start!!!
Old Feb 28, 2004 | 12:17 AM
I8URV8's Avatar
Angry Still doesnt start!!!
Well my gslse still doesnt start.........I am totally lost, I have plenty of fuel, plenty of spark, good compression, timing is good, good injectors, I have no clue what to look for anymore. Itll start once or twice a day but as soon as it starts it dies. It doesnt idle, doesnt let me rev it, doesnt bog down at all, just dies! Can you guys please help me out!? Im going crazy! Thanks in advance!
Daniel
Old Feb 28, 2004 | 01:39 AM
gummie's Avatar
Is the car stock? Where do you live (temprature wise)? If the car is stock, are you playing with the choke?
trouble shooting = nessasary
Old Feb 28, 2004 | 01:45 AM
mazdaverx713b's Avatar
Have RX-7, will restore
is the car flooded??? the gsl-se doesn't have a choke, it is fuel injected. check your fuel filter
Old Feb 28, 2004 | 04:09 PM
I8URV8's Avatar
No its not flooded......and I replaced the fuel filter, I live in New Mexico so the weather is around 40-60 degrees.
Old Feb 28, 2004 | 09:27 PM
GavinJuice's Avatar
Leave A Message
how do you know it's not flooded, did you pull the plugs out?
Old Feb 28, 2004 | 10:18 PM
sa22c_Drifter's Avatar
Does the gsl-se bring an ecu.......it is fuel injected??..
Old Feb 28, 2004 | 10:24 PM
the SE does have an ecu. i believe it is fuel injected, lol, seeing that he said that the injectors are good. is the gas thats in it good or is it old? have you inspected the fuel pump/filter?
Old Feb 28, 2004 | 10:37 PM
have you checked your rotor and cap. maybe they're both rotten. I had a CRX that use to do the same thing and it endep up being the rotor.
Old Feb 28, 2004 | 10:43 PM
perhaps your spark plugs are just worn as well...
Old Feb 28, 2004 | 11:13 PM
Pele's Avatar
Right near Malloy
Vacuum leak would be my first check... Look for any loose hoses.
Double check the ignition components. If it makes spark in open air, it might not make spark in compression.
How good is the fuel?
Old Feb 29, 2004 | 05:30 PM
I8URV8's Avatar
Well i got a new distributor cap and rotor and it started up right away...........revs/idles for a couple seconds then dies.........no sputter no nothing just dies.
Old Feb 29, 2004 | 07:17 PM
KehoeAutomotive's Avatar
How did you check for fuel?
Did you check to see if you have injector pulse?
Old Feb 29, 2004 | 07:45 PM
teencraft's Avatar
Hey I8 we both live in New Mexico, hehe awesome. You're the only person I've ran into who also lives here.
Old Feb 29, 2004 | 08:03 PM
rhinor61's Avatar
Check your fuel pressure, make sure its within factory specs.
I bought a gauge at NAPA that works fine, turns out my 'SE needed a fuel pump.
John
Old Mar 1, 2004 | 11:45 AM
gsl-se addict's Avatar
Super Moderator
I would also check the switch in the AFM for the fuel pump. The SE pump runs when the key is in start and then after the engine starts, the switch in the AFM keeps the pump running. This may expain why it will only run for a couple seconds. One way that you could test it is to put a jumper wire across the terminals of the connector that has a rubber boot next to the AFM. This will bypass the AFM switch and allow the pump to run whenever the key is in the on position. Give it a try and see if it helps anything.
Kent
ZacMan
Sep 19, 2015 09:20 PM
sherff
Sep 12, 2015 12:22 PM
whinin
Sep 5, 2015 11:52 PM
