Fuel line and tank questions
Old Feb 27, 2004 | 09:01 PM
Ported7's Avatar
I was curious if you have to run a return line,I have a holley fuel pump and regulator with a Mikuni intake.Also what lines can you eliminate such as vent,return.Cause right now I have no return or vent hooked up,and my pump gets really loud then really quiet like its going to burn up.I've been running it with no return for years with n o problems,but I think the vent may be causing it.Any input would be helpful.Thanks
Old Feb 27, 2004 | 09:56 PM
mazdaverx713b's Avatar
Have RX-7, will restore
yes you need a return line from what i know. bu if you have no problems...
Old Feb 27, 2004 | 10:21 PM
mwatson184's Avatar
holley guy
How does the FPR work without diverting fuel back to the tank?
-Marques
Old Feb 28, 2004 | 12:02 AM
82streetracer's Avatar
8/1 Building/Drive Ratio
carb regulators just restrict pressure down, instead of bleeding it off with a return like on a EFI system.
Old Feb 28, 2004 | 09:51 AM
mwatson184's Avatar
holley guy
I see, I use a return style regulator with my carb.
The line going to the pressure regulator must have a ton of pressure in it then from being backed up. That would explain why the pump is so loud.
Old Feb 29, 2004 | 01:17 AM
Ported7's Avatar
el pump
It's not that it's too loud,it just gets to where it starts getting really quiet like it's dead.Like I said,never had a problem with no return in a few years.The last carb setup I used didn't even have a return fitting on it.I'm just gonna have to work with it...something tells me its something really stupid as in something I missed when installing it.thanks
Rotospectre
Mar 28, 2018 03:33 PM
