Oil Pressure Swicth and Temp. Swicth?
Ok, the car is running perfectly fine, it's got compression, and it's pumping oil with no prob. The only problem is that my oil pressure gauge is not working. Does this mean the oil pressure swicth is bad??, Did these cars come with oil press. swichtes??, and if so, where is it??. Also I drove the car for a long time today and of course it heated up, but the gauge still read Cold, is the Temp. Swicth messed up too, or do they use another way to read coolant temperature??. Thanks.
the 2 senders are located below the oil filter...but you have a SA.? If you still have the orig engine, then you wil only have water temp...SA have oil level dummy light instead of a gauge.
