vacum hoses question
Old Oct 23, 2001 | 09:32 PM
i want a 3rd gen's Avatar
from what i understand, the vacum hoses are a weak link in the engine. from what i also understand, most of these vac hoses are there for the stock twin turbo setup. so by installing a single turbo will you affectively be removing most of the vac lines and the vac line problems?
thanks for any answers
Old Oct 23, 2001 | 09:36 PM
Bacon's Avatar
IRS 4 Life
when u go single you dont need the solonids...the same is true when you go non-seq, but with a single you will run an standalone and can remove them without a check engine code....or you can put resistors in their place with non-seq on stock ecu
_Tones_
May 25, 2021 05:37 AM
ZacMan
Sep 19, 2015 09:20 PM
NotMrButts
23
Sep 15, 2015 09:46 PM
Tem120
Sep 7, 2015 09:53 AM
Nosferatu
Sep 5, 2015 02:13 PM
