more turbo questions - new rear end
Old Feb 24, 2004 | 11:56 AM
The_7's Avatar
Registered Piston Eater
I'm going to have around 250-300 RWHP when the car is done and i am currently shopping for a new rear end. I want something with limited slip and disc brakes. my question is whats the advantage of the SE rear end over a GSL one. would a GSL one be able to handle that kind of power?
Old Feb 24, 2004 | 12:01 PM
85rotarypower's Avatar
love the braaaap
Yes, the GSL can handle it. But as I understand, the SE rear end can handle more, not to mention you get the more popular bolt pattern. I see more advantages in the SE rear end.
Old Feb 24, 2004 | 12:05 PM
The_7's Avatar
wow that was the quickest response ive ever gotten lol
oh yea i forgot about the bolt pattern. does the se have a different final drive ratio?
Old Feb 24, 2004 | 12:11 PM
love the braaaap
I think so. The GSL has 3.909 in the rear. I think the SE has 4.11, but not totally sure.
Actually, I'm not sure on either number. I for a long time thought the non-SE cars had 4.11 rear end gears. But I have read differently in many places.
Old Feb 24, 2004 | 05:16 PM
S2-13BT's Avatar
If you go with the GSL-SE rear end, you'll probably want to fit the front struts aswell, to maintain the stud pattern front to rear. That may require brake lines to be modded.
Otherwise, if it can handle the power, it's a good idea cause it's all bolt in, and that's always good. You can get different final drive ratios for it, depending on your wants and needs.
smikels
Rtek Forum
May 12, 2016 12:34 AM
mazdaverx713b
48
Apr 21, 2016 06:45 AM
