brake rotor upgrade
Old Feb 24, 2004 | 03:04 AM
pmo123's Avatar
Newbie
brake rotor upgrade
I have an 82 fb and I noticed that the brake rotor and the hub are a single unit. I was wondering if it was possible to put the rotor/hub combo from an 84-85 onto my car get the 4x114.3 bolt pattern, or do I have to get the complete suspension. I have a ford 302 in my car so I need bigger wheels/tires to achieve any traction at all. Any info would be helpful.
Old Feb 24, 2004 | 10:42 AM
Maguire's Avatar
Born 2 Brap
for the fronts you could swap in gsl-se strut housings. you have to switch the whole housing because the spindle is part of it. then you could use gsl-se brakes and rotors. as far as the back... short of swaping the whole rear... maybe you could get some custom axels made.
Frisky Arab
13
Aug 18, 2015 05:30 PM
Marty RE
Aug 13, 2015 11:19 AM
