question on carb float measurements..
Old Feb 23, 2004 | 08:19 PM
natew's Avatar
When measuring the float's do you measure from the gasket or from the metal? Also right under the float there is a cut out so do you measure from the bottom of the cutout or the lip that the gasket sits on?
Old Feb 23, 2004 | 08:35 PM
DONNA's Avatar
i have the two adjustments from a carb kit, with the float upside down you measure 16mm (5/8 in) at the tip of float (not the needle end) and the other measurment with the float hanging down is 51mm (2in) at tip, you should adjust by bending the bend tang (lip that holds the needle), so i would measure from the metal.
Old Feb 23, 2004 | 09:25 PM
slashdawg00110's Avatar
RTFFAQ
Measure from the gasket surface.
Old Feb 24, 2004 | 07:11 AM
Sterling's Avatar
Nikki-Modder Rex-Rodder
Just don't scratch the contact surfaces of the needle tabs or binding/flooding can happen.
Old Feb 24, 2004 | 09:41 AM
RTFFAQ
Thanks for the tip, Sterling. I never thought of that.
Old Feb 24, 2004 | 06:20 PM
joeracer's Avatar
Hmmm, that sounds like that might be my problem while trying to set the float level. I need to check this out, thanks for the tip Sterling.
-chuck-
_Tones_
May 25, 2021 05:37 AM
Nosferatu
Sep 5, 2015 02:13 PM
