245/45s
Old Oct 23, 2001 | 12:02 PM
DavyTailpipes's Avatar
245/45s
Yesterday I bought a set of 17x7 rims with a 40mm offset. The tires the guy at the shop sold me are 245/45/17s. I have an FC and wonder if there will be any rubbing up front. I think rear will be fine. Any advice?
Old Oct 23, 2001 | 01:32 PM
ARD T2's Avatar
Yeah, you should rub. I don't suggest running such a wide tire on such a thin wheel. You should have run a 225/45/17 front and rear, fully rotatable. The 245 won't have as much contact patch due to the "ballooning" effect of the sidewall.
I have three FC's and have encountered problems running anything over a 235/40 and your tire is quite a bit taller than that.
Good luck, RIshie
1POINT3
Jan 13, 2011 06:53 PM
MrGreek
Feb 28, 2008 11:38 PM
cadillacdaddy03
Jun 18, 2005 07:21 AM
SAMIboarder
Jun 9, 2005 12:28 AM
