Sponsored by: CARiD
Hi-temp Coatings Cryogenically Processed Rotors, Good or Bad? Please comment why.
Old Feb 22, 2004 | 06:20 AM
clikel's Avatar
Newbie
Here is a list of coatings and Cryogenic processings that help piston engines that I copied from numerous websites to help those who are not aware of the coating process out there. For those who do know; just ignore it and help with the quesions.
I have 4 questions and yes it all can be done, but what reason for or against it are my questions:
1. The rotor compression face coated as done to the top of a piston to help fight against detonation and keep more thermal energy driving the rotor instead of absorbing into the rotor?
2. The sides of the rotor and housing could be coated like piston skirts or would that flake off or interfere with sealing?
3. The exhaust ports could be coated as well as the exhaust housing of the turbo and exhausts system to help the velocity of the exhaust gases stay higher?
4. Cryogenically process the rotars and housings, maybe the Apex seal 2mm Seals & springs?
====Basic Info====
Rotor and Rotor Assembly Modifications
http://www.hayesrotary.com/page12.htm
MOS2* Treatment to Rotors
Rotors and rotor main bearings are treated entirely with MOS2*, the compression dishes are impregnated with a ceramic coating, and the rotor oil cavity is treated with a high heat transferring coating. The coatings are capable of withstanding temperatures over 1800 degrees Fahrenheit and maintaining excellent adhesion during rapid temperature changes. This combination allows for reduced friction, dispersion of combustion heat, and less retainment of heat. This results in better long-term functioning of rotor seals, increased utilization of fuel, less stress on apex seals, and virtually no carbon build up over time. Recommended for all engines but especially high performance racing applications. PER-400
PISTONS - Piston tops are coated with CBC2, a Ceramic Barrier Coating which provides a layer of thermal protection to the piston tops. This highly polished coating greatly increases part longevity as it reduces heat and detonation.
PISTON SKIRTS are coated with TLML, a “Moly” dry film lubricant which provides the piston with excellent lubricating qualities. TLML will provide lubrication protection during momentary loss of oil film and reduces friction as part temperatures decrease.
CYLINDER HEADS - Combustion chambers on either cast iron or aluminum heads can be coated with CBC2 or CBC3. This coating will help increase thermal efficiency which will produce more usable power. Exhaust flow is also increased when using TLHB on the exhaust ports of the head.
Pistons and Valves
HPC offers two coatings for pistons and valves that can be used together separately of each other based on needs and some class regulations in racing. HPC's thermal barrier coating (TBC) is applied to the combustion face of the piston and a wettable solid dry film (SDF) applied to the skirt.
Probably no part of an engine undergoes greater thermal shock than pistons and valves. Yet this has no effect on the bonding properties of HPC's TBC which has the same coefficient of expansion as aluminum. Particulates are bonded with an inorganic binder which is unaffected by petroleum products. With a bond strength of 10,000 psi, this coating's non-porous ceramic matrix improves flame travel and combustion efficiency as well as reduces oil temperature and prevents carbon buildup. HPC's TBC process also prevents excessive heat from
reaching the piston rings reducing radial tension loss due to the ring overheating. Thermal barrier coating is applied to the combustion face of the valve prevents overheating of the exhaust valve and heat transfer from the intake valve to incoming cool air and fuel, thus providing a denser air/fuel charge. The process works equally well on both two-cycle and four-cycle pistons, and is applicable to new and used parts.
Our HPC S06 is a solid dry film lubricant that is applied to the skirts of the piston to reduce friction and prevent scuffing. This wettable matrix coating is a Molybdenum Disulfide based coating rather than PTFE. Moly is a higher pressure lubricant and does not "cold flow" under pressures exceeding 150,000 psi. Also Moly attracts oil keeping an adequate film of oil on the part. PTFE will shed oil and thus becomes the only lubricant between the piston and the cylinder wall. The Moly is suspended in a thermosetting polymer binder which hardens during curing providing a permanent lubricant unlike break-in Moly sprays. S06 can also be applied to the stem of the valve to reduce friction and wear. Engine bearings are another excellent application for HPC's S06 coating.
---Cryogenically processed
Race teams have found deep cryogenic engine processing to give them an edge on the competition. With the engine components cryoed they can save money on parts and run more on the edge without constant fear of burn down or breakdown.
The advantage that the cryogenic process brings is a significant increase in abrasive wear resistance and durability. These are accompanied by increases in tensile strength, toughness and dimensional stability coupled with the release of internal residuel stresses.
Cryogenically processed motors and othe components have less vibration, less burn downs and less distortion. Treated piston rings seal better against treated cylinder walls reducing blow-by equaling more HP and torque. Race car brake rotors see a 3-5 time life increase after cryo, resisting cracking and warping. Cryoed brake rotors also result in a much longer brake pad life.
Old Mar 20, 2004 | 03:31 PM
1. Yes, it has been done and is a good idea. A thermal barrier allows you to extract the maximum work from the heat of combustion.
http://www.rotorsportsracing.com/per...enginecoatings
2. Also has been done, though I would imagine doing so would be WAY more difficult, and most likey require expensive and precise machining to properly finish. The 787B (the four rotor Mazda that won LeMans in '91) had a cermet coating on its housings.
3. Could be done, though its probably difficult, and it wouldn't do much. Remember, the iron sleeve is there to prevent heat transfer from the exhaust gasses to the rotor housing.
4. Rotorsportracing does cryo treating of rotors. I personally wouldn't do apex seals (I'd rather shot-peen them), but most likely can be done.
bb6guy
Old School and Other Rotary
Oct 1, 2018 08:07 AM
JZW
3rd Gen General Discussion
29
Dec 21, 2016 11:23 AM
bb6guy
Aug 12, 2015 03:29 PM
