99 spec front specific questions
Old Feb 21, 2004 | 11:03 AM
I apologize if this is a repeat question, but '99 is very hard to search for on this forum.
I have a '93 touring and I want to fit the 99 front end to the car. Is everything that is needed included with the RX7-store kit? I'm concerned about non-obvious fitment issues like oil cooler ducting and such. I want to make it an OEM fit.
Old Feb 21, 2004 | 11:51 AM
Herblenny's Avatar
DGRR 2017 4/26-4/30, 2017
Depend on if you get the rebar or not.
If you get the rebar, it should fit fine.. If not, you could either cut your old rebar or take the rebar off..
I recommend if you do 99 front end, get the rebar.. Over time, your urathane bumper will sag.
Old Feb 21, 2004 | 07:31 PM
I will be getting the rebar, my question is about the oil cooler ducts. I think I remember someone mentioning that they aren't the same shape/size, but I'm not really sure, and was looking for clarification.
Old Feb 21, 2004 | 08:58 PM
Herblenny's Avatar
Ok.. This is what I'm doing..
I'm taking those oil cooler ducts out .. I'm ordering 99+ underbelly tray and brake ducts. Apprently the new brake ducts are combination of oil cooler duct and brake duct. One of the guy in AL has the Complete OEM set up with all this.. I've finally had chance to look at it and its definitely what I'm going to do.. I'm going to pick up my tray maybe next weekend and JT import is sending me the brake ducts..
JT quoted around 400-500 for just the belly and ducts.. Definitely go thru him!!
Old Feb 21, 2004 | 10:08 PM
Right, that's the info I'm looking for. Thanks!
matty
Jan 18, 2020 10:39 AM
