Dyno 475rwhp lightly mod'd T2
Old Feb 21, 2004 | 10:02 AM
87GTR's Avatar
Here is the Dyno sheet from when BDC and I took the car to the dyno a while ago. This is on the a BDC Spec C half Bridge port.
475rwhp
382rwtq
we went back 2 weeks later again and busted out 499rwhp and 399rwtq we changed the timing and timing split also cleanned up the map.
Old Feb 21, 2004 | 02:27 PM
razorback's Avatar
You've Been Punk'd
What turbo are you currently using? those are impressive numbers. i am assuming that these numbers are on race gas?
Old Feb 21, 2004 | 07:54 PM
87GTR's Avatar
click on my sig for all the specs on my car.
yes we where using running race gas 499rwhp @ 23psi
Old Feb 21, 2004 | 07:58 PM
Cheers!'s Avatar
Former Rx7 *****
wow... between 4.5k and 6.5k you must be hanging on for dear life... it's too bad the torque curve can't be flatter.
Old Feb 22, 2004 | 02:05 AM
jacobcartmill's Avatar
just dont care.
holy **** 1.5 bar is a lot of air from a T04
Old Feb 22, 2004 | 09:48 AM
87GTR's Avatar
I dont know where you got 1.5 bar on T04. the most I ran on the T04 1bar. the turbo that we made 499 on was S300.
we even had a wastegate control line pop off and boost spike to 1.8bar during the dyno tuning. with no problems to the motor.
Old Feb 22, 2004 | 03:55 PM
razorback's Avatar
You've Been Punk'd
is bdc the one using the t66?
Old Feb 22, 2004 | 05:35 PM
turbo-rotary's Avatar
I think you might be confusing BDC's setup with mine. B did my motor.
I dynoed 447 at 14psi on the T-66
Here is some pics of my car.
http://2stroke.cyberosity.com/Spec'X...Fuel%20System/
http://2stroke.cyberosity.com/Spec'X...ifold/Updated/
Old Feb 22, 2004 | 06:07 PM
razorback's Avatar
You've Been Punk'd
maybe i was. i just know that he did a t66 and it was impressive. is that 447hp on pump gas? i have considered this turbo and if you got those numbers out of it then it may help my decision. do you have a dynosheet?
what are your other mods?
Old Feb 22, 2004 | 09:00 PM
Nope not Brian's car.
He did the motor on it.
It was done on 108 gas. It has a halfbridge motor.
Old Feb 22, 2004 | 09:13 PM
razorback's Avatar
You've Been Punk'd
i have a half bridge. i was wondering how you got almost 450hp out of pump gas on 14 psi.
did you dyno using pump gas? if so what were your numbers?
Old Feb 22, 2004 | 11:15 PM
just dont care.
yes we running race gas 499rwhp @ 23psi
Old Feb 23, 2004 | 01:52 AM
casio's Avatar
casio isn't here.
razor, i have a T04B for sale (pending). its the same one BDC has used as has Hassan (turbo-rotary).
Old Feb 23, 2004 | 01:57 AM
casio's Avatar
casio isn't here.
Tony, did you not like the sig i made for you?? or did you ever even see it ?
Old Feb 23, 2004 | 07:03 AM
Josepi's Avatar
Despise Enmity
Did you ever try the S200?
Old Feb 23, 2004 | 08:12 AM
No, we used 108 as I wrote above. But the timing on the car is very conservative. I only ran 108 for safety reasons. At 10 psi it made 370 running a mid 10 afr. That is what I was drving the car at on a daily basis. (80-90 miles a day)
Old Feb 23, 2004 | 05:47 PM
razorback's Avatar
You've Been Punk'd
i meant did you do any runs using pump gas.
Old Feb 23, 2004 | 05:53 PM
nope...
Old Feb 25, 2004 | 08:07 PM
87GTR's Avatar
yeah we only tuned on race gas. we tune for the street @ 1 bar
Old Mar 5, 2004 | 01:13 PM
20B10AE's Avatar
Gone Darkside
"Lightly modded" ??? I never thought of MY car as that, and I'm fairly close to your mod level. LOL.
Nice numbers, Tony. I hate you.
Reese
Old Mar 5, 2004 | 01:51 PM
fstrnyou's Avatar
Reese
was thinking the same thing.....kinda funny tho, he's making twice the HP than me and I am running 20psi. Stock turbo, IC and injectors aren't helping me either.
Old Mar 5, 2004 | 04:57 PM
87GTR's Avatar
right now the car is lighty mod'd compaird to the plans I have for it.
Reese I cant wait teill we get to build the comso motor I have sitting on the floor. to bad your so far away would be great to hang out with ya
Old Mar 8, 2004 | 12:20 AM
BOOSTED Vert
Wow beautifull numbers!!! nice car... well I got a question.. A while ago I was going to drop in the 13b re in my vert. Now I see that you have that engine, not sure if youre using it, sitting around. Is there an advantage in building the re vs. tII ? Down here I got a good deal on the engine and since a ecu isnt a problem I wouldnt mind subbing the re for the TII that I currently have if its a better buy. Thank you for your input.
Old Mar 10, 2004 | 09:17 AM
87GTR's Avatar
Yeah I have a cosmo engine thats is almost ready to built up for the next car. I cant wait till we can start on that project.
right now the we changed the size and shape of the ports on the T2 motor and also changed from 89 - 91 style turbo rotors to the low compression 87 - 88 turbo rotors. the motor is rebuilt and should be installing it this weekend.
here is a few pics
http://rx7.cyberosity.com/87GTR/pics/2004/03-09/
here is lastest update on the cosmo motor
http://rx7.cyberosity.com/87GTR/proj...re/dec-4-2003/
Old Mar 11, 2004 | 12:18 AM
BOOSTED Vert
alll I got to say is "wow". I love the way the powder coated manifolds came out. Also as to the question that I asked you earlier. What is a better engine to build TII or re ?
