87 TII SP Dyno
Old Feb 19, 2004 | 06:39 PM
2a+RoN's Avatar
87 TII SP Dyno
Dyno'ed my car today with the following mods:
-corksport dp
-mp
-apex n1 dual
-custom 3" TID
-s5 turbo
-streetport engine (all work done by me)
-750cc sec.
-FD fuel pump
-underdrive pulley
-no accessories
-no emissions stuff
-safc
-manual boost controler set at 12psi
MAX HP: 246.5 MAX TQ: 223.2 on Dynojet
Woulda made more power, but the streetport was outflowing the small stock turbo and boost fell off at 5750 in 3rd to almost 8psi!
Old Feb 20, 2004 | 03:59 PM
$150FC's Avatar
Currently Winning
Why'd you dyno in third gear?
Old Feb 22, 2004 | 07:32 AM
RETed's Avatar
Got a pic of the dyno graph?
I find those numbers pretty liberal for a stock turbo?
-Ted
Old Feb 22, 2004 | 07:36 AM
gsracer's Avatar
EIT
Ted, why? I put down 232 at 10.5-11 pounds on a s4 turbo. Sounds like a healthy solid bolt on t2....
Old Feb 22, 2004 | 07:08 PM
13bpower's Avatar
s4 for life
And a streetport as well. The numbers are impressive but not unbelievable.
Old Feb 22, 2004 | 07:32 PM
fstrnyou's Avatar
Not that it matters but my G-Tech Pro says I have 235 at the wheels. Intake, Exhaust, SP, stock inj. stock turbo, stock IC.
Put my stock intake back on to try and bring the boost down a bit but ended up dropping back to 10-11 psi from the 18-20psi. It feels really slow now.
Old Feb 22, 2004 | 07:34 PM
gsracer's Avatar
EIT
18-20 pounds on the stock turbo is WAY the hell out of it's efficiency range. If you're truly running 1.3-1.4 bar your turbo will die very quickly on top of that. More boost does not always equal more power.
Old Feb 22, 2004 | 09:00 PM
RETed's Avatar
A street port usually kills some of the torque, unless someone has got a revolutionary porting technique that somehow leaves the torque high - that's why I'm curious on how the street port was done?
There is nothing different between an S4 versus S5 turbo, so the max power should be about the same.
-Ted
Old Feb 24, 2004 | 06:17 AM
gsracer's Avatar
EIT
-Ted
Well we know the exhuast manifold is of a better design.
I was led to believe the exhuast housing on the s5 was better designed than that of the s4. What is the difference in a/r value between the s4 and s5's exhuast side?
Personally I didn't even notice the torque, but I put down just over 200 rwtq, so that is a good bit less....
Old Feb 24, 2004 | 12:32 PM
CRXtoRX7's Avatar
mmmtrbo.
I saw the dyno sheet, his claims are accurate. His first run untuned produced like 214 hp, but after like 5 more runs they got it leaned out to the correct A/F ratio. I think the reason he produced so much torque is because he barely ported the exhaust, and its running my 2.5 inch dual exhaust right now. Also he didn't specify that his s5 turbo has a p-trim wheel. I will try to get him to scan the dyno sheet.
-Ben
Old Feb 24, 2004 | 07:56 PM
gsracer's Avatar
EIT
p-trim exhuast wheel machined into the stock hotside with just the stock compressor housing/wheel??
Old Feb 25, 2004 | 12:35 PM
2a+RoN's Avatar
p-trim??? I never said I had a p-trim wheel. Its an s5 turbo that was supposedly upgraded by turbonetics(the basic upgrade, i think just compressor wheel) but it looks stock to me. It has the stock turbine wheel and housing. I'll try to get the sheet scanned for you guys. I think the reason I got good torque is because of the porting, I left the primary intakes pretty mildly ported but went large on the secondaries.
Old Feb 25, 2004 | 12:40 PM
2a+RoN's Avatar
Oh and $150FC, yeah, afterwards, I realized I shoulda done it in 4th (the boost feels more solid there too so I think it would made over 250), but the last time I was there they had me do it in third so I just went with that.
Old Feb 25, 2004 | 12:42 PM
gsracer's Avatar
EIT
take off your TID and try to get pics of the front of the turbo on level with the inlet...we can probably figure out what wheel is in there...stock or otherwise
Old Feb 25, 2004 | 01:00 PM
2a+RoN's Avatar
will do. I'm trying to get the scanned graph right now.
Old Feb 25, 2004 | 01:20 PM
2a+RoN's Avatar
here is the graph:
Old Feb 25, 2004 | 01:21 PM
2a+RoN's Avatar
I will take the pics of the comp. wheel in a lil bit. I have seen a handful of stock turbos and my wheel doesn't look any different really, but I'll see what you guys think.
Old Feb 25, 2004 | 03:04 PM
gsracer's Avatar
EIT
time to grab some gsl-se injectors or a pair of 720's for the primaries. You can see on the dyno you're somewhere in the mid 13's for air/fuel before the secondaries come online.
Old Feb 25, 2004 | 04:55 PM
2a+RoN's Avatar
Yeah, there is some room left on the afc to do some more tuning, so I'm gonna try and richen it up some down lower.
Old Feb 25, 2004 | 07:45 PM
CRXtoRX7's Avatar
mmmtrbo.
oops my bad on the p-trim, I knew it had an upgrade(supposedly from the guy you bought it from). Ill just shut up and let the adults handle this...
Old Feb 25, 2004 | 09:41 PM
RETed's Avatar
Yes, and this basically affects low end power.
Compressor still dictates max power.
Turbine A/R dictate power band.
-Ted
Old Feb 25, 2004 | 09:43 PM
RETed's Avatar
OH!  This explains it!
The numbers are way too high for a stock turbo.
I think the Turbonetics wheel is a V-trim, and this makes a lot more sense!
-Ted
Old Feb 25, 2004 | 10:19 PM
gsracer's Avatar
EIT
-Ted
ehhh.....245 rwhp on a v-trim at 12 pounds would be seriously low. I don't see why it's so unbelievable.
Old Feb 25, 2004 | 11:01 PM
2a+RoN's Avatar
Here's a pic of my turbo...
Looks stock to me, what about you guys?
Old Feb 25, 2004 | 11:03 PM
2a+RoN's Avatar
oh and btw, the knife-edging on the compressor was done by me, the compressor housing looked completely stock when disassembled.
