Haltech Am I the only one....
Old Feb 19, 2004 | 06:11 PM
Project84's Avatar
Open up! Search Warrant!
with a haltech on a N/A engine? If not, I I want to know else else does so I can see how your maps look
Old Feb 19, 2004 | 09:27 PM
RETed's Avatar
Gonna do one soon...on a 20B
It depends if you're going TPS or MAP dependent?
-Ted
Old Feb 19, 2004 | 10:18 PM
Project84's Avatar
Map dependent. What else do you need to know? I got 720cc primaries and 1680cc secondaries.
Old Feb 20, 2004 | 01:01 AM
RETed's Avatar
Wow, your NA planning to make over 500hp??
-Ted
Old Feb 20, 2004 | 07:45 AM
rxrotary2_7's Avatar
HOLY **** thats a lot of fuel for a n/a
Old Feb 20, 2004 | 11:53 AM
Project84's Avatar
I got nitrous too. I have a TII motor than I'm planning to rebuild. thats what the injectors were for originally. I figure it wouldn't be impossible to get them to work in a N/A with the Haltech.
Old Feb 20, 2004 | 12:47 PM
$150FC's Avatar
Currently Winning
****, you don't even need to fire the 1600s
you gonna be doing the tuning yourself?
Old Feb 20, 2004 | 08:19 PM
Project84's Avatar
I want to. Its not a daily driver and I think I can learn how to do it without blowing anything up.
Old Feb 20, 2004 | 11:24 PM
Project84's Avatar
You guys figure the 1680s are too big. Should I use a 460 primaries 720 secondaries with the N/A and a 75hp shot of NOS?
Old Feb 20, 2004 | 11:31 PM
RETed's Avatar
I would run maybe 4x550's at the most and run the NOS set-up with wet nozzles, controlling the fuel enrichment with the NOS fuel jets.
The Haltech has this funky 2-minute wait "safety" feature that prevents you from engaging the NOS switch before then.
-Ted
Old Feb 21, 2004 | 01:07 AM
tims's Avatar
I have a Haltech on my new N/A engine. I am using the 4-550's. MAP not TPS. just finishing tuning.
Old Feb 21, 2004 | 01:43 AM
Project84's Avatar
I'll have to do 2x460 and 2x720. I don't have any 550s.
tims, can you email me your map so I can look at it?
Old Feb 21, 2004 | 11:56 AM
tims's Avatar
when I have it finished. remind me in a month or so.
Old Feb 21, 2004 | 02:32 PM
pengarufoo's Avatar
The mystery of the prize.
I have e6k on a 6 port street ported motor running 4 550's.
dyno tuning this spring, but the maps probably won't be much use to you... the configuration is a bit unique.
Old Feb 21, 2004 | 04:31 PM
Project84's Avatar
I just want to see a map to get an idea of what it should look like for a N/A engine.
Old Feb 21, 2004 | 08:38 PM
pengarufoo's Avatar
http://www.hitman.hm/maps.htm
hitman has some NA maps up.
Old Feb 21, 2004 | 10:14 PM
Project84's Avatar
Yeah, I saw those before but I forgot about them. Thanks.
Old Feb 23, 2004 | 07:35 PM
RX7145's Avatar
-SE with Mods
Re: Am I the only one....
I do
Old Feb 24, 2004 | 02:47 PM
Project84's Avatar
The 1680s are way too big. I'm using the 460's (don't have any 550s) and the 720s. Still need to turn down the injector impulses cause its idling at 2500 and the exhaust is rich enough to run another engine.
PaulAber, what kind of injectors are you using and are you stagging them?
Old Feb 24, 2004 | 03:56 PM
RX7145's Avatar
-SE with Mods
Stock injectors, And I'm staging them, Thats the way Steve set it up. Works good for me.
Old Feb 24, 2004 | 04:08 PM
RX7145's Avatar
-SE with Mods
Double Post
Old Feb 24, 2004 | 04:19 PM
RX7145's Avatar
-SE with Mods
Old Feb 26, 2004 | 03:15 AM
Project84's Avatar
Hey, thanks a lot for the maps. After looking at it and reading the manual some more, I think I should set mine up for TPS load sensing. I have a map sensor that I can leave open to atmosphere and let the ECU computer changes in the Baro pressure. Looks more comprehensive that way since its a N/A.
Old Feb 26, 2004 | 03:20 AM
RX7145's Avatar
-SE with Mods
TPS works best on a N/A set up. I hope you get yours working soon
Old Feb 26, 2004 | 04:07 PM
pengarufoo's Avatar
any technical explanation as why 'tps works best on NA' ?
you don't need to connect map sensor for barometrci correction, the e6k has an internal pressure sensor for barometric correction.. just turn it on.
