Great, fuel injector trouble
Old Feb 19, 2004 | 05:47 PM
BigJim's Avatar
trainwreck
Well i bought my new engine and today i was putting on the fuel rail with my fuel injectors. The injector holes on my new engine are alot deeper than my old -se ones. I dunno if my injectors will still fit, thats what your for. Any ideas?
Old Feb 19, 2004 | 07:12 PM
gsl-se addict's Avatar
Super Moderator
BigJim,
Do you have the air bleeds in the holes? Do you have the insulator bushings and o-rings for the injectors?
Kent
Old Feb 19, 2004 | 07:51 PM
BigJim's Avatar
trainwreck
i found out, its somehtign called a diffuser. i gotta take it out my old engine nad puit in my new ones
Old Feb 19, 2004 | 08:09 PM
rhinor61's Avatar
They usually break when I try to remove them from a old engine,
Might want to give MazdaTrix a call.
John
Old Feb 19, 2004 | 08:11 PM
BigJim's Avatar
trainwreck
how much do they cost?
Old Feb 19, 2004 | 08:13 PM
rhinor61's Avatar
OUCH...
INJ AIR BLEED PRIMRY
84-88 N/T 13-2600-N305 $39.38 ea
Old Feb 19, 2004 | 09:48 PM
LongDuck's Avatar
84SE-EGI helpy-helperton
Here's your part:
These help to atomize the fuel spray coming out of the injector to provide a more uniform mixture. You might also want to consider new injector seal kit to cover any leaks from using old injectors. Over time, they shrink down and get compressed and can leak. Good luck,
Old Feb 19, 2004 | 09:59 PM
BigJim's Avatar
trainwreck
interesting, very interesting. Does that goes on the end of the injector, or inside the injector housing?
Old Feb 19, 2004 | 10:01 PM
LongDuck's Avatar
It fits down into the hole on the top of the engine for the injector, and the rubber O-rings that you see on the diffuser allow it to seal in the injector hole. The fuel injector then seats against the top of the diffuser (right side, in the illustration) to form the lower seal.
These inserts are necessary to get the proper length to allow the fuel rail to snug down and seal both injectors against their top and bottom mounts. Additionally, there's an O-ring that goes around the upper feed end of the injector to further seal the rail under high fuel pressures. HTH,
86rxNa
Aug 11, 2015 11:51 AM
