Starter Wiring
Old Feb 18, 2004 | 11:22 PM
bcool's Avatar
Rest In Peace Dave
Starter Wiring
Okay, so i bought my Rex w/o a tranny in it so now i have got it reassemebled, push started it, and it runs great. Now i finnaly got my starter and just a bit confused where everything goes in the pic i talked to someone a little about it and was told that the wire w/o the boot bolts onto the one of the tranny bolts (4) i was curious to find out if anything acctually bolts onto terminal (1) i know that the small clip goes on terminal (2) and i assume the booted wire goes on terminal (3) just want to double check this for when i install it tomarrow, thanks
Old Feb 18, 2004 | 11:25 PM
AcidShock's Avatar
Eet fase
If I remember correctly, #1 is the hot wire, #2 is the switched power, and #3 is the negative terminal. The starter ground goes to a transmission bolt farther up.
Old Feb 18, 2004 | 11:40 PM
bcool's Avatar
Rest In Peace Dave
Oh yes and this mystery wire? also does anything else connect to terminal 1 or is it just that one main wire?
Old Feb 18, 2004 | 11:49 PM
AcidShock's Avatar
Eet fase
That needs to be grounded. It escapes me what exactly it is for, but I believe it has to do with the clutch slave cylinder. Mine is just underneath one of the bolts on the slave cylinder.
Old Feb 19, 2004 | 12:05 AM
TonyTurboII's Avatar
Glock Lover
1 goes nowhere
2 gets the little clip
3 gets the booted wire.
Put the mystery ring on the bolt that goes through the starter, transmission and rear housing.
Old Feb 19, 2004 | 12:10 AM
bcool's Avatar
Rest In Peace Dave
alright thanks man
toplessFC3Sman
Mar 20, 2018 01:54 PM
Monsterbox
Sep 11, 2015 03:29 PM
