how many fins on an s4 stock turbo?
Old Feb 16, 2004 | 08:26 PM
hondahater's Avatar
spending too much money..
Thanks.
Old Feb 16, 2004 | 10:04 PM
hondahater's Avatar
because mine has eight
Old Feb 16, 2004 | 10:33 PM
White_FC's Avatar
Exhaust side?
I count 11 on my stock S4 turbo....
Old Feb 16, 2004 | 10:53 PM
hondahater's Avatar
no intake side
Old Feb 16, 2004 | 11:04 PM
White_FC's Avatar
6 big ones, 6 small ones.
Old Feb 16, 2004 | 11:08 PM
hondahater's Avatar
so why would I have 8?
Old Feb 16, 2004 | 11:15 PM
White_FC's Avatar
Upgraded compressor section I'd imagine..
Got any pics/measurements of it?
Does it just have 8 large fins, no small ones??
Old Feb 16, 2004 | 11:51 PM
hondahater's Avatar
no it has eight large and eight small. Damnit how come I just can't get a regular stock turbo. Grrr. If this one works I will like it but my last turbo had 7 fins and it never worked. I'll post pics tomorrow
Old Feb 17, 2004 | 02:08 AM
BlackRx7's Avatar
Daily Domestic Killer
if it has 8 large and 8 small fins it is most likly upgraded, but hey if you need a stock S4 turbo a got a rebuild one siting right next to me...wanna trade?
Old Feb 17, 2004 | 07:26 AM
hondahater's Avatar
hehe, well I don't mind the upgraded one as long as it works. I had a stock s4 originaly then I got an upgraded one that never spooled so I'm kinda leary but if it works, great.
Old Feb 17, 2004 | 10:54 AM
hondahater's Avatar
here is a pic of the turbo.
Old Feb 17, 2004 | 10:58 AM
hondahater's Avatar
here is the turbo I bought a while back that is on there right now that I haven't been able to get it to spool.
https://www.rx7club.com/attachment.p...postid=2631896
Old Feb 17, 2004 | 11:00 AM
hondahater's Avatar
and here is what a stock turbo for s4 looks like, notice how both the "upgraded" ones have thinned intake walls compared to the stock one.
https://www.rx7club.com/attachment.p...postid=2631880
Old Feb 17, 2004 | 02:06 PM
hondahater's Avatar
so does that look like an upgraded turbo?
Old Feb 17, 2004 | 04:23 PM
White_FC's Avatar
Yes dude, it looks to be an upgraded compressor. Which is a good thing
Old Feb 17, 2004 | 04:44 PM
hondahater's Avatar
do you see the other one right below that? what is that? I know it doesn't spool
Old Feb 17, 2004 | 04:48 PM
Digi7ech's Avatar
I break Diff mounts
It's upgraded. It looks like the intake housing has been machined wider to accept the fins.
I would try and figure out from the previous owner what type of upgrade it was.
Also you might need to upgrade your fuel to go with this turbo. 720's secondaries and a SAFC.
Old Feb 17, 2004 | 05:07 PM
White_FC's Avatar
Thats an upgraded turbo aswell, theres probably heaps of wheels you can machine out the stock compressor to take.
no idea as to why it wouldn't spool, the bearings look ok as the ends of the fins aren't bent up along the compressor housing edge or anything. Must be something wrong with it on the exhaust side.
Or some other prob.. Intake leak? who knows.. could be anything.
Old Feb 17, 2004 | 06:24 PM
hondahater's Avatar
ok thanks guys. I already had 720 secondaries and upgraded fuel pump, safc, tid mod, hks intake, and msd ignition but this thing still won't spin. Dont' know what as soon as I put this other one on and it works I'm going to get rid of theat other turbo for cheap! if anyone is interested.
Old Feb 17, 2004 | 06:30 PM
Chris Ng's Avatar
I'm with stupid -----^
here's a pic of a stock s4 turbo compressor housing beside a to4B compressor housing.. you can see the diffrence in fins.. the compressor wheel on the to4 is a super "V" trim...
Old Feb 17, 2004 | 06:33 PM
BlackRx7's Avatar
wait you said it won't spin? like you can't spin it with your fingers or can you? either way I'll take it off your hands
Old Feb 17, 2004 | 07:13 PM
Digi7ech's Avatar
I break Diff mounts
BTW what is that hole on the compressor outlet on the stocker? Mine is empty like that and I have no idea where it's supposed to go.
I'm guessing it will cause a boost/vac leak.
Sorry for the semi hijack.
Old Feb 17, 2004 | 07:19 PM
White_FC's Avatar
Dude that is a pretty important nipple!
It's the hose for the wastegate actuator! If you don't have that hooked up to your wastegate you will overboost to buggery... like hello 20psi.
So, in short, you should really connect it up.
Unless you have your wastegate actuator getting its signal from elsewhere for some reason? but that is the 'best' spot for it.
Old Feb 17, 2004 | 07:25 PM
White_FC's Avatar
Arrghhh! damm forum making me do silly double posts.....
Old Feb 17, 2004 | 08:05 PM
hondahater's Avatar
no it spins fine and no shaft play just for some reason won't spool up in my car. If I have the same problem with the new turbo its got to be something else but I think that its the turbo. I changed all gaskets vac hoses, etc... it still won't boost.
