Oil filter o-rings..
Old Oct 22, 2001 | 11:05 AM
tesla042's Avatar
The oil filter o-rings which are prone to leaking.. is it mazdatrix p/n:
10-1601-9954.....O-RING OIL FILTER.....TOWER ALL.............. $ 3.30
Don't want to order the wrong part... Also, I hear there are 2 rings... do I need 2 of those, or is that a set?
Thanks!
-Tesla
Old Oct 22, 2001 | 03:53 PM
Evil Aviator's Avatar
Rotorhead
That sounds correct, but you may want to ask Mazdatrix to make sure. You can also get the o-rings from your Mazda dealership. There are 2 o-rings, and the tightening torque on the two bolts is 6-8 ft-lbs.
Old Oct 22, 2001 | 05:55 PM
95R2-89TII Ground Zero's Avatar
Banned
I replaced mine last summer, and its not that bad. Yes there are two of them and they sound like the right part. I paid about twice that much though.
Old Oct 22, 2001 | 06:02 PM
turbojeff's Avatar
Do it right, do it once
I've gone to my local parts store several times to buy the o-rings for the oil filter pedestal, cost is like $.35/ea. They have worked fine for about 6 FCs and 4 FDs I've done.
Your original rings will look different because they are flattened, just buy some regular o-rings...
Jeff
Old Oct 22, 2001 | 06:45 PM
tesla042's Avatar
Jeff
Do you know the sizes? I'd rather not put my car out of commission before I have the pieces ready..
-Tesla
Old Nov 13, 2001 | 03:46 PM
RX-Revvin's Avatar
How did it go Tesla?
Did you end up getting the o rings from mazdatrix or your local dealer? Or did you get some from an autoparts store? I'm curious because I also found a leak around the oil filter/pressure sender area and I'm not sure which it is so I figure I'd go with the cheaper fix first.
Old Nov 13, 2001 | 05:32 PM
tesla042's Avatar
Re: How did it go Tesla?
funny you ask today... I called up the dealership this morning, and discovered that the part number is the same as the one in my orig post from mazdatrix.. about 3$.. I'll pick it up tommorow, and prolly do the install over the weekend.. Hopefully i'll take pics.
-Tesla
The1Sun
Mar 18, 2018 11:08 PM
gxl90rx7
Haltech Forum
Sep 14, 2015 03:09 PM
rotor_veux
Sep 3, 2015 07:10 PM
