Power FC injector setup in PFC
Old Feb 16, 2004 | 03:38 PM
Zyon13B's Avatar
"I see triangles"
I'm going from the stock setup to bosch 1600 sec with resistors and using the old 850 secs in the pri. What numbers should I use for injector setup in the PFC? I'm not quite sure of the lag on the 1600s. Thanks in advance for any help you can give.
Old Feb 17, 2004 | 06:23 PM
cewrx7r1's Avatar
Eye In The Sky
Start with a lag of about 10 to 20. A search might show this as many have done it before and have posted here.
The instruction manual tells how to change the values for injector sizes. You really will need a datalogit to change some transition parms for smoothe transition from primary to secondary injectors.
Old Feb 17, 2004 | 08:52 PM
Zyon13B's Avatar
"I see triangles"
thanks. but I was wondering if anyone who is useing the same setup could give me their #'s for a starting point. I got the sec injs and rail from Keith.
sctRota
Old School and Other Rotary
Nov 10, 2015 12:57 PM
bryancmatthews
Power FC Forum
14
Oct 5, 2015 08:49 PM
ZacMan
Sep 19, 2015 09:20 PM
