Whats the difference....
Old Oct 21, 2001 | 06:17 PM
RedT2's Avatar
Newbie
between a 91 J spec and a 87 T2 engine? Just recieved my 91' J-spec engine, and just ripped out the 87' T2 engine. I found that the 91' engine is somewhat different from my 87'. Can't really figure out some differences so any help would be useful....
Old Oct 21, 2001 | 10:46 PM
Rx_treme's Avatar
uhm k on the 91
the turbos are more effecient
higher compression/lighter rotors
no twin scroll
some other stuff i'm not remembering right now
this will at least get some thoughts flowing now
Jason
Old Oct 21, 2001 | 10:49 PM
TonyTurboII's Avatar
Glock Lover
The front cover is different, It uses a mechanical OMP, and youll need to swap the old cover on. Im pretty sure youll also need to use your old intake. Besides that I dont know.
Old Oct 22, 2001 | 12:00 AM
Scott 89t2's Avatar
SOLD THE RX-7!
yoru probably going to want to find a 89-91 ECU and harness to run it... otherwise the timming will be off do to plug loction difference. as well as the OMP is run off the ECU. if you want to run your ECU the front cover and OMP have to be swaped as said above.
either way is a bitch.
should have gotten an 87-88 motor
Old Oct 22, 2001 | 05:11 PM
red t2 conversion's Avatar
I found out that the intake manifold's are different but they're not interchangable. The wholke the patterns are slightly different idk what the f*ck to do, so any help?
Old Oct 22, 2001 | 05:52 PM
95R2-89TII Ground Zero's Avatar
Banned
You'll have to modify the current one, or have one custom made. Thats the only way.
Old Oct 22, 2001 | 06:35 PM
SpeedRacer's Avatar
Formula Mazda Driver
Your also gonna need the 88.5/91 fuel injectors. Check thepartstrader.com for used parts you are gonna need.
onefastrx712a
Mar 13, 2011 12:51 PM
twinturborx7pete
109
Jul 15, 2009 04:13 PM
fernquidy
Mar 10, 2008 04:36 AM
shift.
16
Feb 2, 2006 05:35 PM
shift.
1st Gen Archive
15
Feb 2, 2006 02:13 AM
