Rear disc brake question?
Old Feb 11, 2004 | 08:19 PM
the Wizard's Avatar
Hi guys,
Newbie here, with an easy question. I understand that the piston in the caliper on the rear brakes rotates to retract during a pad change. That pin on the pad is strange though. If the pin locks into the cut-out or slot...then it seems as though the piston can't rotate as it comes back out? Does it move out without rotating?
Thanks, Ross
Old Feb 11, 2004 | 08:22 PM
Stoops417's Avatar
not sure, but i belive the piston does NOT rotate during normal brake operation, only when a special tool is used to manually retract it for a pad change.
Old Feb 11, 2004 | 09:18 PM
KehoeAutomotive's Avatar
I know that AutoZone will loan that tool for you for free if you leave them a deposit.
I have a shop and never needed to borrow tools before but the other day I boke my P/S puller and they loaned me one until I went to Sears to get a replacement.
Old Feb 11, 2004 | 09:59 PM
Siraniko's Avatar
RX for fun
just buy it at harborfreight. they have a set for less than $20.00. dont be a cheapo and use a big channel lock to rotate it.
Old Feb 11, 2004 | 10:33 PM
the Wizard's Avatar
Back to the question....does it rotate out or come out straight?
Old Feb 11, 2004 | 10:50 PM
theweasel's Avatar
It comes straight out, rotates only to retract.
Old Feb 11, 2004 | 11:16 PM
the Wizard's Avatar
OK cool...thanks guys...I guess that explains it.
mazdaverx713b
48
Apr 21, 2016 06:45 AM
Marty RE
Aug 13, 2015 11:19 AM
