88 TII Dyno (few mods)
Old Feb 10, 2004 | 10:28 PM
MountainTurbo's Avatar
Here is the dyno that the previous owner of my car did. I have an S5 Turbo and manifold to go on now (He said he thinks the stock turbo is on it's way out), and a warlbro fuel pump. I'll probably also grab some 720cc secondaries, and a MBC to up the boost a tad. Also, the TB mod has been done since this dyno, don't know how much difference it makes. Anyway:
Stock Motor (140,000 miles), Stock TB, Stock injectors and pump, Stock Turbo and Wastegate, Stock ignition. Emmissions stuff still on (airpump, cat, etc).
Mods that mattered: Cone intake w/TID mod, Down Pipe, Highflow Cat Converter, RP50 2.5" Catback.
Rock solid 8lbs of boost reading on autometer guage
MAX HP: 215.7 MAX TORQUE: 186.8
Old Feb 10, 2004 | 10:36 PM
It was running pretty dang rich (especially for the stock fuel system I would think!), even after he leaned it out 8% on the S-AFC. The red line is the leaned-out run (not much difference). With more boost and a little better tuned fuel curve, should put out some decent power
:: crosses fingers ::
Old Feb 11, 2004 | 04:10 PM
13bpower's Avatar
s4 for life
215 Wheel HP? At only 8 psi? that is very impressive. I want to get mine dynoed.... I just need a safc.
Old Feb 12, 2004 | 02:03 AM
jacobcartmill's Avatar
just dont care.
wow you were gettin pretty rich around 4500-5000. i'd watch it i'd richen it up in the midrange there and lean it out in the topend.
Old Feb 17, 2004 | 04:08 PM
just dont care.
i meant to say lean instead of rich in the midrange
Old Feb 19, 2004 | 01:32 AM
gsracer's Avatar
EIT
You're running lean in the mid range, from 3500-5500 it looks like mid 13 air fuel ratious!! Get a walbro on there, the stock fuel pump is the weak link of the fuel system.
Old Feb 19, 2004 | 01:51 AM
just dont care.
it looks to me like it almost gets up to 14... bad times
Old Feb 19, 2004 | 02:40 PM
bryantho's Avatar
Those air fuel numbers would be good on a N/A piston motor; but you don't have one of those. For $.02 I'd fix that spike and richen up the entire band.
Old Mar 22, 2004 | 12:34 PM
Barwick's Avatar
SCCA Rookie
dang that's a peaky torque curve for a turbo rotary, especially with the stock turbo.
My '90 TurboII had a Kansas-flat torque curve @ 5.5 lbs, put 193.8 at the rear wheels on a mustang dyno (more accurate than a dynojet dyno). Still the sucker ran 13.75 @ 104.8 in the 1/4 mile... wonder what yours will run.
Old Mar 23, 2004 | 12:34 AM
just dont care.
i dont think you can run 104 mph in the 1/4 at 5.5 lbs of boost...
Old Mar 25, 2004 | 01:26 AM
Yah, I definately want to get it out to a track and see how she does
befarrer
Old School and Other Rotary
Oct 5, 2015 03:30 AM
Clacor
Sep 11, 2015 08:36 PM
mulcryant
Sep 9, 2015 05:24 PM
acha3
Sep 6, 2015 08:14 AM
