carbon or stock??
Old Feb 8, 2004 | 12:46 PM
wwilliam54's Avatar
it WILL run
carbon or stock??
im starting to gather parts for a bridged 12a this summer
i cant decide if i want carbon or stock seals
i like the carbons, since less stuf will break, and rebiulds will be cheaper when they pop
but i know stockers "should" last longer
BTW I dont plan on taking it past 9500rpm
Old Feb 8, 2004 | 02:03 PM
Rx7carl's Avatar
Airflow is my life
Carbons are good for engines that see hi rpms all the time. ie-race motors. If your driving on the street, then you lose any advantage they give. Carbons show lower compression numbers than iron seals at low rpms.
Old Feb 8, 2004 | 02:04 PM
wwilliam54's Avatar
it WILL run
itll be a combo street/drag/autox
and not a dailey driver
ill think about it, them not killing housings is tempting
Old Feb 8, 2004 | 02:22 PM
mazdaverx713b's Avatar
Have RX-7, will restore
i would stick with the stock apex seals. unless you are driving it more on the track than on the road.
Old Feb 8, 2004 | 04:12 PM
REVHED's Avatar
Hunting Skylines
If you plan on seeing 9500rpm on a regular basis that pretty much rules out the stock seals. Have you thought about going for a "softer" steal seal like from Hurley?
Old Feb 8, 2004 | 04:14 PM
wwilliam54's Avatar
it WILL run
not really, but ill look into it
in fact I dont really know much at all about hurly
Old Feb 8, 2004 | 04:24 PM
REVHED's Avatar
Hunting Skylines
An other thing is, if you cut a big bridge-port on the primaries and secondaries with matched rotor-housings you run the risk of dislodging the apex-seal corner piece. Some of the after-market seals have a longer corner piece to overcome this. With carbons it obviously doesn't matter as they're one-piece.
Old Feb 8, 2004 | 04:55 PM
wwilliam54's Avatar
it WILL run
for stockers i was gonna go half with one set turned reverse
edit:
im convinced
with the lack of my needs for a dailey driver
and no sound laws in mississippi
full bridge with carbons are the way to go
sYnth.
Aug 19, 2015 06:27 PM
