need power from ignition switch
Old Oct 20, 2001 | 01:45 PM
Montrealer's Avatar
Yes this is an other post about the DLIDFIS,
Everything is setup and ready to go, except the power source, I was hoping that by using the stock leading coil wires it would give me voltage off the ignition switch but that is aparently not the case. I know that there is voltage on the stocktrailing coil wires (which are capped off) I am wondering how it would be easyest to get the voltage to finish the job.
Is it possible to use the power from the stock trailing wires?
Or is there a safer/better way to do this?
Thanks, the car is on standby
Old Oct 20, 2001 | 03:27 PM
REVHED's Avatar
Hunting Skylines
If you have voltage at the trailing coil + you should have voltage on the leading + because they are on the same circuit. If not just run jumper wires from the trailing + to both leading coils and to the ignitors. As long as they're all on the same circuit it should be fine.
Old Oct 20, 2001 | 05:16 PM
Montrealer's Avatar
I have voltage on my trailing wires but they are not connected to the coil because i am no longer using the stock harness. those wires are capped.
Is there an other place I can get the current or can I just connect those "useless" wires to gve me voltage?
Old Oct 20, 2001 | 06:01 PM
REVHED's Avatar
Hunting Skylines
Yep, by all means just splice into the existing trailing + wire.
Boriquaguerrero
20
Apr 22, 2019 01:15 PM
C. Ludwig
Jan 30, 2019 06:31 AM
LunchboxSA22
37
Oct 26, 2015 10:53 AM
befarrer
Microtech
Aug 22, 2015 05:52 PM
