13B Rotor housings all same???
Old Oct 20, 2001 | 11:39 AM
rreader's Avatar
Question 13B Rotor housings all same???
Does anyone know if the 13B rotor housings from a GSL-SE and the second generation are the same? I'm thinking the end castings maybe different but the rotor housing maybe the same, does any know for certain??
Thanks
Jim
Old Oct 20, 2001 | 12:14 PM
peejay's Avatar
Old [Sch|F]ool
No they are not.
In '86, Mazda moved the coolant O-rings from the rotor housings to the side housings. This basically means you can't interchange any housings between -'85 and '86+ engines.
They also changed the geometry a lil' bit in '86 so you're supposedly not even supposed to interchange rotors, but I've heard of people doing it.
Ciclovnz
Oct 18, 2015 03:04 PM
cdn
14
Sep 10, 2015 06:23 AM
VTECthis
Aug 24, 2015 09:01 PM
cdn
2nd Generation Non-Technical and pictures
Aug 11, 2015 08:59 PM
