Vacuum readings?
Old Oct 19, 2001 | 06:53 PM
thatoneguy's Avatar
Vacuum readings?
What should the normal vacuum readings at idle when the car is warmed up? I'm getting -36 cmHg. Is that a bit high?
Old Oct 19, 2001 | 08:35 PM
twelvinches's Avatar
Newbie
Most stock get 18-20. Do a search on the topic. Yours seems excessively high.
Old Oct 19, 2001 | 11:16 PM
jr's Avatar
jr
Actually your reading a little low, but nothing to worry about. 38cmHg = 15inHg. That's weird though, I've never seen a gauge with centimeters instead of inches, does your boost read in PSI or Bar?
Old Oct 20, 2001 | 02:37 AM
thatoneguy's Avatar
I have a Blitz Turbo Timer/Boost Gauge, so it reads in Bar.
Old Oct 20, 2001 | 02:52 AM
f2racer's Avatar
Both my FDs were a little bit funny. Regardless of how hard I tried to adjust, they both idled around 500 rpm. I know that this is about 200-300 rpm less than what it's supposed to. At this rpm, my car gets between 12-14 in/HG. Funny thing is when I add electrical load (such as truning on the parking lights) into the equation, the car automatically ups the idle up to about 700 rpm, and vacuum goes to 15-17 in/HG.
Old Oct 20, 2001 | 05:27 AM
maxcooper's Avatar
WWFSMD
Porting, altitude, and idle RPM can change the readings significantly, but most healthy stock-ported engines give 15+ inHg, and ported engines tend to make less vacuum. A street port should give about 12+ inHg.
-Max
Old Oct 20, 2001 | 10:49 AM
Nike178's Avatar
Hey, at least im not alone. My car idles at 500 all the time. As soon as i put my lights on, the idle jumps to about 750. I thought it was just my fd cause i never heard this. Any suggestions?
ZacMan
Sep 19, 2015 09:20 PM
t-von
Sep 10, 2015 01:56 PM
doritoloco
Sep 5, 2015 12:41 PM
Frisky Arab
Sep 4, 2015 06:17 PM
