Clock stays on in GSL-SE
Old Feb 2, 2004 | 01:30 PM
scottt80's Avatar
I have an '85 GSL-SE. The clock stays on all the time. The LEDs are bright and keep the correct time. I'm concerned about it running the battery down, but haven't taken the time to check the dark current. Is it normal for it to stay lit up with the key out of the ignition?
Old Feb 2, 2004 | 01:36 PM
web777's Avatar
It's supoposed to stay on. LED's are very very low voltage.
Old Feb 2, 2004 | 01:38 PM
werd's Avatar
Its normal for the clock to stay on. It wont run your battery down either, unless maybe you let it sit for weeks or something. Ive let mine sit for 2 weeks or so and it started up fine.
Old Feb 2, 2004 | 01:51 PM
scottt80's Avatar
Well I knew it couldn't use much power at all, but it worries me as the car may be sitting as long as 2 to 3 weeks at a time. Glad to hear that yours stay on also though. Thanks for the replys.
Old Feb 2, 2004 | 02:08 PM
mazdaverx713b's Avatar
Have RX-7, will restore
should be fine. if in doubt, disconnect the negative battery cable.
Old Feb 2, 2004 | 02:17 PM
MyRxBad's Avatar
EliteHardcoreCanuckSquad
This was my favourite feature of the LCD clock in my GSl-SE. If you were standing outside of it and wanted to know the time you just peaked inside.
LCD screens use next to nothing power wise. I mean, if your solar calculator can do it, then the clock is nothing.
Old Feb 2, 2004 | 06:41 PM
jorx81@aol.com's Avatar
Still Dreams of 3rd Gen
the clock probably uses less power than the self discharge of the battery, in the sc summer for sure.
Old Feb 2, 2004 | 09:12 PM
jimtesla's Avatar
Well............
My Se does not light up..............
Never has..........is there a fuse for this?
Its cool finding out another feature that I may have.....
Old Feb 2, 2004 | 10:15 PM
rx7gslse's Avatar
EX Pres of DFW Drunks
LCD or LED?
there is no factory LED on an SE. The black/grey LCD should stay on all of the time... Think how long a watch battery lasts.. like 2 years. I don't think it's gonna kill your car battery anytime soon staying on
Old Feb 3, 2004 | 07:23 AM
MyRxBad's Avatar
There is a small regular bulb behind the clock that lights up when you turn on the parking lights. That's about it.
Old Feb 3, 2004 | 07:49 AM
jimtesla's Avatar
as far as the light goes......thats what I thought....
but you never know......my key hole is suppose to light up too when you pull up on the drivers handle......nope.....
that lilltle bulb is a bitch to change......not worth the effort.....
Old Feb 3, 2004 | 10:29 AM
scottt80's Avatar
Check your fuses, the clock memory and the key hole light are on the same one I think...
Old Feb 3, 2004 | 02:29 PM
Jeff20B's Avatar
Lapping = Fapping
I had a watch battery last for 10 years. Doesn't the GSL-SE clock have LED backlighting? Nah, it's probably just a light bulb.
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
Sh00bs
Oct 1, 2015 11:57 PM
NickNac113
13
Oct 1, 2015 09:25 PM
