I put a clutch into my car.... no go....
Old Feb 1, 2004 | 04:00 PM
Unhappy I put a clutch into my car.... no go....
Well, me and a friend went to work on my Blue 84 yesterday....
We dropped the tranny and swapped clutches....
Put it all back together this morning, and put in new needle and seats in the carb....
Bled the clutch, ect.... clutch is REALLY strong... but is always on... never disengages.... Since this is an older 12a with an older flywheel, I think I stuck in the 83-88 pressure plate which caused it to trip out or something.... gonna drop it the tranny and put in a different one I guess..... Does anyone know if I can just adjust something? cause im all out of Idea's!
Thanks, Laterz, Andrew
EDIT: I did drive it by getting push started by my brother and keeping steady speed till it warmed up enough to actually drive it.... It runs GREAT and drives GOOD... but to shift gears you have to match speed, to rpm for everygear... and you cant get moving again if you stop..... so i dunno what ima do.... this really sucks.. I dont want to drop the tranny again... so any ideas appriciated......
Old Feb 1, 2004 | 05:44 PM
joebeer's Avatar
extending the push rod @ clutch pedal may cure the problem. another **** I learned from wacky. maybe one of these days, I will shift to rotaries too.
RotorMotorDriver's Avatar
Seven Is Coming
Did you put the clutch disc in backwards?
~T.J.
Old Feb 1, 2004 | 06:01 PM
joebeer's Avatar
~T.J.
rotary may not be a specialty but how can you put the disk in backwards???
Old Feb 1, 2004 | 07:28 PM
rod is all the way out... two more thread and it would be on the floor....
clutch disk being backwards isnt possible....
I just used a newer pressure plate on an older flywheel.... not compatible....
Skeese
Rotary Car Performance
Oct 28, 2020 11:01 AM
Th0m4s
Feb 26, 2019 02:04 AM
alphawolff
Nov 17, 2015 05:57 PM
CaptainKRM
14
Aug 26, 2015 09:52 PM
