Sponsored by: CARiD
Question about Apex Seal?
Old Jan 30, 2004 | 03:21 PM
suckme_up's Avatar
When you blow an Apex seal on the first rotor, it makes your car run really rich, is it possible to get an AFC to tune it to run a little bit better?
Old Jan 30, 2004 | 03:41 PM
rynberg's Avatar
Re: Question about Apex Seal?
So, let me get this straight? You blew your motor and you want to buy a fuel computer to lean it out to run better? Good grief!
Old Jan 30, 2004 | 03:57 PM
suckme_up's Avatar
Sorry man!!!
Sorry man, I didn't blow my engine, a friend of mine blow his an Apex Seal on the first rotor... just looking to see if there were any suggestions? thanks alot man!!!
Old Jan 30, 2004 | 04:32 PM
b00b's Avatar
hahahahahahahaha
Old Jan 30, 2004 | 05:08 PM
CrackHeadMel's Avatar
Learned alot | Alot to go
no, well yes, Yes its possible, No you shouldnt do it because the engine is blown, dont waste your time
Old Jan 30, 2004 | 06:32 PM
christaylor's Avatar
For perspective:
"Hey, I shot two pistons through the valve cover of my 302 Ford. Can I just duct tape the holes and tune the engine to run with 6 of its 8 original cylinders operational? Thanks!"
Old Jan 31, 2004 | 12:19 AM
RETed's Avatar
Re: Sorry man!!!
It's called a rebuild.
-Ted
Old Jan 31, 2004 | 10:55 AM
jeremy's Avatar
male stripper
first get to bottles of naws. the really big ones. then start running a gasoline/methanol mix with 2 qts of atf in it to help with the loss of compression in the front rotor. see where this gets you and THEN see if you need the fuel controller.
Old Jan 31, 2004 | 12:52 PM
villision's Avatar
A WAR WITHOUT WEAPONS
Are you kidding me....is this guy for real?
he obviously needs to sell that car...does he even know where to put the oil at?
Ty
Old Feb 2, 2004 | 01:07 PM
BigTone's Avatar
I almost feel sorry for him
Clubuser
11
Aug 31, 2015 12:25 PM
VTECthis
Aug 24, 2015 09:01 PM
