font rotor magically un-blew an apex
Old Jan 29, 2004 | 02:39 PM
wwilliam54's Avatar
it WILL run
WTF!!
i went to check compresion
6 pulses
awesome
Old Jan 29, 2004 | 02:47 PM
Steve Shulz's Avatar
Compression test results? Just cause its whooshing doesnt mean its enough. I am glad to hear it though.
Old Jan 29, 2004 | 03:25 PM
O 16581 72452 5's Avatar
The infamous number guy!
The seal was simply sticking.
Old Jan 29, 2004 | 04:48 PM
DriveFast7's Avatar
Blood, Sweat and Rotors
Time for Amsoil Power Foam. Clean that motor out!
Old Jan 29, 2004 | 05:30 PM
wwilliam54's Avatar
it WILL run
and how
Old Jan 29, 2004 | 06:45 PM
Wankelguy's Avatar
My FSP Fiesta eats Jettas
Sure you don't want to put some ATF in there?
(j/k)
Let the Power Foam sit in the motor as long as your patience will allow and then start it and drive it at highway speeds for at least an hour to be sure that the slot gets cleaned out real good. Make sure to buy a lottery ticket on the way home, you lucky...
Old Jan 29, 2004 | 06:55 PM
wwilliam54's Avatar
it WILL run
hehe
im driving it home saturday
ill get a ride back to my college place
and let it soak all week
when i drive it back, its an hour drive
so no prob
Old Jan 29, 2004 | 06:56 PM
wwilliam54's Avatar
it WILL run
ive heard a ***** blown rotor seal woosh
i know what your talking about
it wosshes pretty good
Old Jan 29, 2004 | 06:57 PM
DriveFast7's Avatar
Ya know.... I heard antifreeze is really good for cleaning valves and unsticking piston rings . . .
Old Jan 29, 2004 | 07:34 PM
pratch's Avatar
Mazspeed.com
I had 6 strong wooshes - and had 25 compression all around. Hook up the gauge and find out. It's so much better to be safe than sorry.
Old Jan 29, 2004 | 07:36 PM
wwilliam54's Avatar
it WILL run
$$$ is the issue
the butt dyno will tell the tale
Old Jan 29, 2004 | 09:50 PM
TheTwinTurboRX-7's Avatar
money, why
a compression guage is like 20 bucks
and lot so folks usually have them
Old Jan 29, 2004 | 10:01 PM
wwilliam54's Avatar
it WILL run
Originally posted by TheTwinTurboRX-7
money, why
20 bucks
hmm, ill think about it
im pretty broke right now
Old Jan 29, 2004 | 10:04 PM
1stgen4life's Avatar
Leaking oil like crazy!
Is this power foam better than the water treatment?
Old Jan 29, 2004 | 10:05 PM
wwilliam54's Avatar
it WILL run
i hope so
i water treated it recently
but mines running richer thatn **** due to a carb prob
Old Jan 31, 2004 | 03:02 PM
peejay's Avatar
Old [Sch|F]ool
Water doesn't do a damned bit of anything unless you're adding the water under full load.
I don't trust anything by Amsoil (Am Soil) because of their shady business practices. However, if you use any serious decarbonizer on a rotary you MUST follow it up with a lube bath (teaspoonish of ATF/MMO/motor oil just like unflooding) because it WILL wash away the oil embedded in the rotor housing surface and compression will go to **** for a little while. Found that out the hard way.
Old Jan 31, 2004 | 03:24 PM
grantmac's Avatar
What would you consider a serious decarbonizer? I have reason to believe that my motor has some intense carbon and I've tried everything to try and get it clean, do you have any other products that might work.
Grant
Old Jan 31, 2004 | 04:21 PM
Wankelguy's Avatar
Amsoil Power Foam or Techron concentrate.
I'm not fond of Amsoil's multi-level marketing, myself.
But I'd hardly call them shady, in fact they are about the most forthright company when it comes to information about their products. But I've been using Power Foam for about ten years now, and I can fully recommend it with no reservations.
Old Jan 31, 2004 | 06:00 PM
grantmac's Avatar
Man I wish we had that stuff around here. As far as I can tell it's impossible to get anything really effective for clearing carbon up here in Canada, that and the lack of MMO is brutal.
Grant
Old Jan 31, 2004 | 06:09 PM
KehoeAutomotive's Avatar
Where do I get Amsoil Power Foam?
Wankleguy talks highly of it. Napa and autozone does not carry it.
Old Jan 31, 2004 | 06:57 PM
do you pour it down the car or put it in the spark plug hole and bump the starter and pour some more in?
Old Jan 31, 2004 | 09:21 PM
wwilliam54's Avatar
it WILL run
soaking in atf for a week since mississippi doesnt have any powerfoam apparantly
atf does work in my experence, just not the best
Old Jan 31, 2004 | 11:07 PM
rx-7ames's Avatar
have any of you read the thread about cleaning the carbon out with water. i personally have never done it but i don't think i have a big carbon build up problem. if all the recomended cleaning stuff is hard to find where you are then maybe you could try the water treatment.
Old Jan 31, 2004 | 11:10 PM
wwilliam54's Avatar
it WILL run
i did that like a week before my seals stuck
it did nothing
Old Jan 31, 2004 | 11:44 PM
bliffle's Avatar
Geez, you guys. Just add 4 to 8 oz. of MMO to every tankful and it works fine.
B
