Power FC Future PFC newbie question...
Old Oct 18, 2001 | 02:20 PM
Dimcorner's Avatar
Man Whore
I might get a PFC with base maps... Will i need to tune it based on my mods?
3mm seals
GT Ported engine
dowel pinned
hardened stationary gears
Power Pulley
Pettit Intake
Down Pipe
Mid-Pipe
Cat-back
8.5# flywheel
Everything else is stock (IC, ignition, fuel pump, and injectors)
TIA
Jo
Old Oct 18, 2001 | 02:43 PM
vosko's Avatar
Just Call Me Terminator!
you can run the base maps but if you get it tuned you will make more power. i would wait till you get bigger injectors to pay for tuning of the pfc to save money in the long run. might want to get pfc boost kit with it so you are ready for more than 17.5 psi because your pfc will have to be retuned to get maps higher than 20psi. i wish i knew all this when i first got mine!
Old Oct 18, 2001 | 03:25 PM
Dimcorner's Avatar
Man Whore
so basically the PFC with the base maps will be fine correct?
I mean right now i have a Pettit regular remapped ECU and was wondering if it was going to make a difference.
Old Oct 18, 2001 | 03:37 PM
vosko's Avatar
when you are at the point where you need more fuel or want to go single turbo i would suggest going powerFC or haltech etc. the pettit is a great unit that can get you into the 11's with good enough driving if you want to get pfc with base maps it will be fine. you will notice the car will idle and run alot smoother with pfc. if you have the $$$ pfc is nice but it depends how far you wanna go with your car.
eplusz
15
Oct 7, 2015 04:04 PM
Einheri
Oct 7, 2015 12:23 PM
baix2
Power FC Forum
Sep 28, 2015 09:40 AM
