Is there an oil cooler drain plug?
Old Oct 18, 2001 | 11:59 AM
Mykl's Avatar
Stupid question, I know. But I'd like to know for sure before I remove the plastic rock guard thing to drain it.
I've never drained it on an oil change, and I'd like to start doing that.
Thanks
Old Oct 18, 2001 | 07:22 PM
10TH_ANNIV_T2's Avatar
Yes, a rather large bolt right near where the cooler line connects. It's something like 28 or 29mm. I couldn't get it loose until I had the cooler off the car.
Good luck!
Greg O
Old Oct 18, 2001 | 08:30 PM
No Drain
The large "nut" you are referring to is the special bolt that holds the oil cooler bypass thermostat valve in place. It is not a drain and is most certainly not designed for frequent removal. There is also a thin copper gasket washer that will not withstand reuse.
The bolt is steel and the oil cooler is aluminum. Frequent removal without proper precautions will result in galled threads and a leak at best, and most likely a ruined oil cooler.
There is no reason to drain the oil cooler when changing the oil. There is a negligable amount of oil in the cooler. If it were necessary to drain the cooler Mazda would have made it easier to get to and furnished a drain plug there.
Old Oct 19, 2001 | 12:09 AM
Mykl's Avatar
Okay, thanks for the advice, I'll leave it alone.
I guess I thought it held more than it actually did.
FD7KiD
15
Feb 26, 2021 10:12 PM
FD7KiD
Aug 17, 2015 11:50 PM
