GSL over SE ???
Old Oct 17, 2001 | 09:52 PM
Gizmo's Avatar
Universal Genius
GSL over SE ???
well, im no a big freak of carbs... any advantage over injection?
opinion on that? anyting thanks!
Old Oct 17, 2001 | 10:15 PM
peejay's Avatar
Old [Sch|F]ool
Well for one thing you don't have to worry about getting stranded if your trailing ignitor dies...
really the difference is a lot more than carb vs. injection... the SE engine is a whole different engine, the SE has bigger brakes front and rear, a different wheel bolt pattern, it reverted to the (better) air/oil cooler, it usually costs a lot more to buy one, ...
Old Oct 17, 2001 | 10:35 PM
Gizmo's Avatar
Universal Genius
yeah, i know that,..
question more based injection vs carb... or 12A vs 13B 6 ports
Old Oct 17, 2001 | 11:10 PM
speckamp's Avatar
8krpm is not enough
The 12A is a 4port 1.2 liter block, but you knew that. The 13B is a 6 port 1.3 liter block, with higher compression rotors, a half-way decent fuel injection system, 3mm apex seals, 35 more BHP stock, ect.
If you can find a GSL-SE, get it! Starting with the bigger engine will put you a step ahead of the 12A guys. There are plenty of 2nd gen guys w/ NA 13B 6 port blocks (pretty much the same as the GSL-SE's until 88) pushing 200HP.
--matt
NickNac113
13
Oct 1, 2015 09:25 PM
