a few tranny questions
Old Jan 23, 2004 | 12:16 PM
first off...what are the differences, if any, between the turbo 5spd and the gxl 5spd?
how difficult is it to rebuild these trannys? i have lots of experience rebuilding piston engines (just rebuilt and installed a lt1 in a 86 fiero) but none with trannys. should i try to do it myself or just save up and have it done?
thanks
Old Jan 23, 2004 | 12:45 PM
Hot_Dog's Avatar
Re: a few tranny questions
thanks
Gear ratios, diameter of input and output shafts, number of bearings, and case design.
I wouldn't attempt it unless you have access to a hydraulic press.
Hot_Dog
90 RX7 GXL
02 Acura RSX-S
Old Jan 23, 2004 | 12:55 PM
SureShot's Avatar
Seduced by the DARK SIDE
Check out the on-line factory manual PDF's.
Download the transmission section.
There is a link in my sig.
cleann88
Jan 15, 2022 11:28 AM
sinclair7seven
11
Sep 11, 2015 10:15 AM
