how is everyone lower'd here heated spring/cut ??
Old Jan 22, 2004 | 09:18 PM
Tree25is's Avatar
Wink how is everyone lower'd here heated spring/cut ??
=JUST KIDDING=
But seriously how is everyone lowerd here ????
since my car was only 100 bucks heating up the springs and droping it would hurt me to much but i know its the WRONG WAY TO GO. anyways how are you lowerd?
Old Jan 22, 2004 | 09:22 PM
Wankelguy's Avatar
My FSP Fiesta eats Jettas
Shorter, heavier springs.
Old Jan 22, 2004 | 09:37 PM
DriveFast7's Avatar
Blood, Sweat and Rotors
when i didn't know better i had my springs heated in my high school 82 Ford EXP. absolutely the WORST way to lower a car. heating makes the springs brittle and dangerous. plus they get very very bouncy.
but it was cheaper than cutting them. of course now i know to buy some shorter, stiffer springs. go Racing Beat if you want performance or Eibach Pro-Kit if you want it not as stiff.
Old Jan 22, 2004 | 09:51 PM
Tree25is's Avatar
your wheels on the rx-7 where did they come from , there sweet !
Old Jan 22, 2004 | 10:15 PM
DriveFast7's Avatar
http://diamondracingwheels.com/RoadRaceSeries.htm
13x8" BACKspace get the road race series, they have tighter tolerances
Old Jan 22, 2004 | 10:26 PM
QuagmireMan's Avatar
Registered Offender
i hate being lowed i cant drive anywhere without hearing a painful scrape
Old Jan 22, 2004 | 10:46 PM
Tree25is's Avatar
sweet thanks ! i love em low. my bimmer is really low so im used to low ****, the rx-7 is able to be low. its kinda durable compared to the alumium oil panned BMW!
Old Jan 23, 2004 | 12:20 AM
onepointone's Avatar
i say what i want
my friend has a lowered bimmer as well, and he has that same problem. we were going through a burger king parking lot in his e30, and there was this nasty scrape, all his 2 day old oil went all over the parking lot. sucked at the time, but was funny afterwards.. atleast to me
DriveFast7 - what did you do to your racecar? i know those arent eibachs or racing beat springs, unless they have been cut. do you have the racing beat lowering kit?
Old Jan 23, 2004 | 08:28 AM
Rx7carl's Avatar
Airflow is my life
I thought Eibachs were stiffer than RB's?
For a soft street ride, Suspension Techniques are progressive in the front and softer than Eibachs or RB's. They lower about 1" or so.
Old Jan 23, 2004 | 08:44 AM
vipernicus42's Avatar
Rotoholic Moderookie
I wasn't aiming to get lowered, but the RB springs are like .8" lower than stock. I probably won't notice a difference when I put them in because my old springs were so shot that they were pretty damn low!
But yeah, the safest, smartest and funnest way to lower is to get performance springs. That way you lower your car and instead of losing performance to look good, you gain it!
Jon
PS: I actually don't think lowering looks much better most of the time... but huge honkin' wheel well gaps don't look the best either... I'll post pics in the spring when my RB Springs and KYB shocks are in
Old Jan 23, 2004 | 09:12 AM
peejay's Avatar
Old [Sch|F]ool
My car is "lowered" by having the original springs.
Mazda used the same springs for all 1st-gens. Look at the old ads and magazine pictures and notice where the wheel center was in relation to the rocker panels in the '79. Then look at them in '81, in '84, on the GSL-SE... you will notice a pattern. Every year, every time the car got heavier, the car'd get lower. Because Mazda used the same springs and rates, even though a fully loaded GSL-SE weighs lots more than a strippo '79. Even the later GSLs were weighed down like the GSL-SEs because most of the weight difference between the GSL and GSL-SE was in the brakes and wheels, which are of course unsprung weight and so don't affect ride height. (My GSL has A/C and P/S as well as sound deadener/insulation everywhere you look, and it sits *low*)
Now. Add 20 years of aging on the springs, and the cars sit even *lower*.
Most lowering springs actually raise the car, because the ride height difference is as compared to a new car, and who has a new 1st-gen? (Nobody!) This is good though, because the suspension geometry isn't that great at stock ('79) ride height and it only gets worse as you go lower.
I am working on fabricating some spring spacers to raise my car up. (1, 2, or 3 inches from where it is now, still pondering on the best way to go about it) Suspension travel is important, sop is good geometry. Certainly more important than getting the CG slightly lower!
Old Jan 23, 2004 | 12:03 PM
Wankelguy's Avatar
Why you trend-bucking heretic!
I like that...
Old Jan 23, 2004 | 02:28 PM
DriveFast7's Avatar
Eibach Pro-Kit front springs are progressive. cushier than RB on flat roads, start to stiffen up once compression starts
Old Jan 23, 2004 | 02:42 PM
purple82's Avatar
Absolute Power is Awesome
Actually SAs had stiffer, taller springs than FBs. They have different part numbers.
Old Jan 23, 2004 | 11:51 PM
1984se's Avatar
Ryan
https://www.rx7club.com/attachment.p...postid=2167502
Old Jan 24, 2004 | 12:11 AM
BIG J MIXALOT's Avatar
SHSHSHA POCKET SAND
is it better to cut or heat up the springs
Old Jan 24, 2004 | 12:23 AM
RotorMotorDriver's Avatar
Seven Is Coming
That happened to me at work one time!! I was pulling a lowered tricked out E30 M3 into the washing bay and theres a little mini speed bump type thing at the entrance as to keep the water inside the garage bay thingy so it goes down the drain and not all over the lot. Anyway, I was pulling it in, and the suspension was really stiff and really low, so right as it dropped over that bump, it bounced once really hard and the next thing I knew when I got out I was standing in a pool of oil. Luckily the parts department had a couplde oil pans in stock, and they just wrote it off, but it sucked, lol.
~T.J.
Old Jan 24, 2004 | 01:33 AM
i say what i want
Originally posted by RotorMotorDriver
....E30 M3...
im sorry... what?
Old Jan 24, 2004 | 01:54 AM
mazdaverx713b's Avatar
Have RX-7, will restore
heated springs, ugh!!!!! get a set of eibach's. works well!
Old Jan 24, 2004 | 01:59 AM
Jon_Valjean's Avatar
Don't know about you guys, but heated/chopped springs are illegal here. Can't beat a good set of King's or Jamex springs to drop it down a coupla inches
Old Jan 24, 2004 | 02:09 PM
peejay's Avatar
Old [Sch|F]ool
Care to elaborate? I'd love to see free lengths/spring rates.
AFAIK the only different springs are that RHD cars have a right front spring .5" longer than the left, whereas LHD cars have a left front spring .5" longer than the right.
Old Jan 24, 2004 | 02:14 PM
FD Racer's Avatar
sold the FD...kept the FB
coilover setup with 2.5" eibach 350lb. springs, along with racing beat's lowering kit in the front. In the rear I eliminated the watts link and did a trilink setup from G-force with a panhard bar and 250lb. short springs
Old Jan 24, 2004 | 02:17 PM
Jeff20B's Avatar
Lapping = Fapping
Before they had slightly longer springs on one side, they had a .5" spacer on the driver's side. My Cosmo has one.
Old Feb 15, 2004 | 06:36 PM
i say what i want
where did you get those springs?
granted the car is still in the air, and has been in the air for a long time, but for the picture i jacked the car off the stands by the rear diff (i dont have lugs for the wheels yet, so i cant put it on the ground). im not liking that wheel gap at all. i have eibach springs on my other car, but they are the pro-kit and i dont know if it will do the trick. i plan to do ground controll coil overs in the front, but what about the rear? i dont want it up like that.
Old Feb 15, 2004 | 07:12 PM
MosesX605's Avatar
My wife bought me 2 RX-7s
Check out these springs from mazdatrix:
http://www.mazdatrix.com/getprice.as...ACESPRING-1R-2
They are 175 pounds/inch and have several dead wound coils so you can cut without affecting the rate. That should give you the height you want, but the rear end will be STIFF.
