rotor won't fit on struts
Old Jan 21, 2004 | 08:09 PM
krazy_1st_gen's Avatar
strut problems
i just got a pair of front struts from a 1982 rx-7. i put it on my 1980 and ran into a problem. the spindle on the 82 struts is to big. the bearings in the rotor that goes on the spindle is too small. my question is can i get the rotor bearings form a 1982 and put it on a 1980 rotor, or do i have to get the whole rotor from a 1982. please help. any and all info will be appreciated
Old Jan 21, 2004 | 11:30 PM
rhinor61's Avatar
That makes no sense at all cause the '79-83 use the same inter and outer wheel bearings, and the same rotors.
Are you sure you don't have 84-85 spindles, just because they were off of a '82 car does not mean that they are '82 parts. Swaps are very common.
Don't believe me about '79-'83 being the same parts, look it up at the MazdaTrix web site.
John
Old Jan 22, 2004 | 12:04 PM
i never said i don't believe you. i guess it's 84-85 struts. now i gotta go back and get the rotor and hub assembly.is the spindle on 84-85 shorter and fatter? if it is i got 84-85 struts. thanks
Old Jan 22, 2004 | 01:39 PM
Steve Shulz's Avatar
You may even have GSL-SE struts, check the bolt pattern of the rotor, that will tell you for sure.
Old Jan 24, 2004 | 03:52 AM
its GSL-SE struts, now i just have to find an adapter fitting for the calipers so i can use my ss brake lines. anybody know who sells them. i looked on mazdatrix website but can't find it. any info would help. thanks
Old Jan 24, 2004 | 07:55 AM
What rear end do you have? Youre gonna end up with two different rim back/front.
Old Jan 24, 2004 | 06:44 PM
im jus tryin to swap the front for now. the rearend is stock for now, not completely stock. got LSD. i jus want the bigger brakes in the front. when i have more money i will be swaping the drums to disk in the rear. not worried about rims or size on car.
Old Jan 24, 2004 | 06:48 PM
Thats good because the rims you have wont fit on those struts. Youll need to get the 114mm bolt pattern (SE) size.
Old Jan 26, 2004 | 02:14 PM
i got 2 O.Z. rims for the front. if i didn't have no rims i can jus ask my friends for some honda rims or sumthin. i jus need an adapter piece for the brake lines now
