Microtech How long till you could drive it?
Old Jan 14, 2004 | 04:02 PM
1987RX7guy's Avatar
Eat Rice Don't Drive it.
I was wondering how long it took you guys with LT8's and LT12's to be able to drive the car after the initial intallation: wiring and plugging everything up.
Also does the ECU come with a base map or do you have to make your own from scratch?
Thanks guys!
Santiago
Old Jan 15, 2004 | 07:44 AM
Josepi's Avatar
Despise Enmity
ECU comes with a base map...once everything was back together, it cranked up the first time and ran pretty damned well too.
Old Jan 15, 2004 | 12:48 PM
LT8TurboII's Avatar
IT took us about 6hrs to install mine, and I drove it from Dale Clarks house to my house that night.
Old Jan 15, 2004 | 05:46 PM
Mark'sMazda's Avatar
stop stealing my avatar
4-7 hours seems like the norm.
Yes, the car will run very well on the base map, so long as you don't have any heavy mods.
Old Jan 15, 2004 | 08:59 PM
Aaron Cake's Avatar
Engine, Not Motor
All mine have been drivable as soon as finished. However, the base map is way rich. You'll want to pull out quite a bit of fuel before you actually start to drive the car.
Old Jan 16, 2004 | 12:30 PM
bl|nk's Avatar
Fok mi
After mine was wired up.. 9 hours.. cause it was 4am when i finished so I went sleepy then it cranked right over and ran like a gem
Old Jan 16, 2004 | 12:43 PM
silverrotor's Avatar
Sounds very familiar, eh Aaron?
Aaron wired up my LT8 exclusively. With some down time, I was able to Install my Koyo Rad, sandblast everything In sight and once again review Aarons wire up as from last week. Damn, you did a good job. It's very clean and subtle and It didn't take that long.
Old Jan 16, 2004 | 05:48 PM
1987RX7guy's Avatar
Tony, do you have pics of the instal? I want to see how things are wired up and how the wire harness looks.
BTW is the kit a flying lead like the haltech's or is it already completed with all the connectors and such?
Old Jan 17, 2004 | 11:49 AM
It's a fly lead and connectors have to be transfered. I have no pics of the overall up to date setup. In time, I'd like to post a few.
Old Jan 17, 2004 | 04:00 PM
Aaron Cake's Avatar
Engine, Not Motor
I have pics of the process, but they are far from complete and were taken under...poor...conditions. Wiring harness pretty much looks however you want them to look. Tony's was done in wrapped black electrical tape. We tried to find a type of "sleeve", but couldn't get one locally.
Old Jan 17, 2004 | 04:03 PM
Wait to you see the overall completion Aaron. I've even polished off my Intercooler Pipes. Now - I've gotta Install the GReddy FMIC Kit. Kudos buddy.
Old Jan 17, 2004 | 04:11 PM
1987RX7guy's Avatar
From what I can think of the connectors I would need would be: Injectors, TPS(GM in my case), air temp sensor, MAP sensor??, what other connectors are needed? BTW are any connectors included with the kits?
Santiago
PS- Thanks for helping me out guys. I can't wait till I get it.
Old Jan 17, 2004 | 08:05 PM
https://www.rx7club.com/showthread.p...hlight=install
Old Jan 17, 2004 | 08:32 PM
1987RX7guy's Avatar
thank joo
Old Jan 18, 2004 | 03:17 PM
Aaron Cake's Avatar
Engine, Not Motor
I recommend replacing all stock connectors with modern weather pack (or is that WeatherPak?) connectors. They are used on newer GMs and Fords and unlike the Mazda sensors, are completely waterproof...
BTW, why do you want to run a GM TPS? The Mazda unit is already on the engine, mounts up without any modification, and works well. The Microtech is not nearly as sensitive to TPS problems as the stock ECU. The Microtech only uses the TPS to decide when the car is off-idle.
Old Jan 18, 2004 | 04:12 PM
1987RX7guy's Avatar
The TPS is not on my car. It was stolen before I bought it. Therefore it is easier to buy a 48 dollar gm sensor and spend 3-5 dollars on making a bracket than going on ebay and spending 80-100 dollars on a used S5 TPS. which even at that is cheap for an S5 TPS.
Old Jan 21, 2004 | 07:06 PM
Fox4Life's Avatar
Hey aaron, where can i get some of these connectors you are taking about? Im getting ready to install my MT and i dont want to use any of my old half-burnt plugs.
Old Jan 22, 2004 | 10:51 AM
Aaron Cake's Avatar
Engine, Not Motor
You can't be serious. S5 TPSs sell used for $20. I sell them on eBay all the time for under $30 US. Or, you could just use the S4 unit. Bolts right up and cheaper as well...
Weatherpack connectors are available from most auto parts stores like NAPA, Car Quest, etc...
Old Jan 22, 2004 | 11:12 AM
1987RX7guy's Avatar
I am deadly serious. Aparantly your out of touch with supply and demand.
Old Jan 22, 2004 | 02:59 PM
LT8TurboII's Avatar
You can use any of the FC plunger style TPS's just mount it on the required bracketry from your model year and have the connector for the other side of it for the Microtech. I wouldn't bother with buying a GM unit.
Old Jan 22, 2004 | 05:00 PM
Aaron Cake's Avatar
Engine, Not Motor
No, I just don't rip people off. I literally have a bucket full of TPSs, from every year. At least 5 S5 units. Maybe I should start pricing them at $90 US instead of what they're worth?
Seriously, I wouldn't worry about the TPS too much with a Microtech. Just use whatever TPS you have (s4 or S5). Unlike the stock ECU, the Microtech only relies on the TPS to determine idle/off idle. Dead spots don't matter unless they effect the first few degrees of travel...By the time you make the bracketry for a GM TPS, you could have probably bolted on an S4/S5 RX-7 TPS and moved well onto much more important things...
Old Jan 22, 2004 | 05:13 PM
1987RX7guy's Avatar
Not all people price them fairly. Thats why I said supply and deman. But if I can just use the S4 tps I have a spare one so that drops the cost a little more
Santiago
82streetracer
Haltech Forum
11
Mar 11, 2019 05:34 PM
sherff
Feb 24, 2019 12:09 PM
ncds_fc
Aug 15, 2015 10:06 AM
