Sponsored by: CARiD
Is it possible to Bi-charge a rotary?
Old Jan 13, 2004 | 02:22 PM
TyCity's Avatar
Is it possible to supercharge turbocharge a rotary?
Ive heard of and seen bi-charged nsx and mr2s with superchargers and a turbochargers
the torque and horsepower band are excellent
I just wanted to know if it was possible for a rotary engine
Old Jan 13, 2004 | 02:25 PM
apreludem's Avatar
what bi-charge??
Old Jan 13, 2004 | 02:27 PM
eViLRotor's Avatar
Brother of the Rotary
Yeah? I have not seen that term used too much.
If you mean running 2 turbochargers, then yes.
Old Jan 13, 2004 | 02:29 PM
supercharger (for low RPMS) and turbo (for high RPMS) in the same car. Lets you get the best of both worlds for forced induction systems. Usually works well and a lot of MR2s have it. Im not sure about doing that to a rotary but honestly I dont see why not...Keep in mind that it takes ALOT of custom work tho and its prolly expensive as hell.
casio's Avatar
casio isn't here.
turbo, supercharger. don't know if anyone would also count nitrous.
anything is possible, but how many do you really see? what do you consider excellent? you can have excellent on a high compression engine, or a well built turbo or supercharged engine. wouldn't rather not waste your money? comply, be normal.
Old Jan 13, 2004 | 02:43 PM
TyCity's Avatar
by excellent i mean torque is similar to horsepower and horsepower is high
Old Jan 13, 2004 | 05:41 PM
chairchild's Avatar
50mpg - oooooh yeah!
Get a normal turbo 13b, and place a constant displacement supercharger (Whipple?) AFTER the intercooler, just before the inlet.
SC works all the time, yet the turbo will force in higher amounts of air into the SC when it's spooled up. Use a piggyback ECU, and you're done, but an air-to-water intercooler after the SC would be a good idea for performance.
Old Jan 20, 2004 | 05:49 PM
MountainTurbo's Avatar
Or, you could just do what this guy did, and do a blower, twin-turbos, and N20.
Course, the engine is a LITTLE bigger than a 13B
Old Jan 20, 2004 | 08:53 PM
Lancia Delta S4
Lancia Delta S4. 650hp in 1985, but that car was a little bit SMALLER than a 13b (1.5 liters).
Old Jan 20, 2004 | 09:03 PM
System
Diagram of system:
Remember kids, an engine + supercharger will spool a MUCH larger turbo. Like a nitrous hit you never have to refill.
Old Jan 21, 2004 | 02:25 AM
kyle@insight's Avatar
Dont like it? I dont care
Wouldn't that produce a LOT more heat? Last thing a rotary needs is more heat....
Old Jan 21, 2004 | 06:46 PM
chairchild's Avatar
Then get a bigger radiator and intercooler
Old Jan 22, 2004 | 12:48 AM
Yea who needs a hood? I'll just take off my hood and have a custom radiator made and mount it there. Function follows form right?
Old Jan 30, 2004 | 03:44 AM
Zio's Avatar
Zio
Re: System
Originally posted by CypherNinja
Diagram of system:
Custom intercooler and radiator can remove a lot of heat, and who said any engine likes heat.
Piston engines run hotter than a rotar so they have more to worry bout.
Old Jan 31, 2004 | 03:59 PM
Choser's Avatar
This would be sick.
But it will never happen, sadly.
Old Feb 8, 2004 | 10:08 PM
ASE_Joe's Avatar
only thing better than a blown and turboed car would be 800ci of raw power
datfast1
Old School and Other Rotary
18
Jun 20, 2019 10:53 PM
Under PSI
19
Sep 23, 2015 11:47 PM
datfast1
West RX-7 Forum
Sep 14, 2015 06:58 PM
andyvideopro
SE RX-7 Forum
Sep 5, 2015 06:56 PM
Murilli
Midwest RX-7 Forum
Sep 3, 2015 09:10 AM
